squonk 45,038 #1 Posted February 7, 2014 On the mid grader lift link, what is the hole on the pin used for? Is it for the threaded rod link that attaches to the crank arm? It looks like there are 2 mounting spots on that end. Is it either or? Use the threaded rod link or use the small pin directly into the crank arm? Thanks Share this post Link to post Share on other sites
Marv 994 #2 Posted February 11, 2014 Mike, Here is a picture of the link hookup. The Large hole is never used as I recall. I just thought it was used because it was an item already in stock used on the leveling rod for mowers. Marvin 1 Share this post Link to post Share on other sites
squonk 45,038 #3 Posted February 11, 2014 Marvin No picture??? Share this post Link to post Share on other sites
