MaineDad 87 #1 Posted September 9, 2008 I came home from work and discovered that the hydraulic lift cylinder I bought for my C-160, the original is leaking, was delivered. I changed up and headed to the garage. I took the left foot rest off and proceeded to remove the lift cyclinder. I pulled it off and for some stupid reason decided to manually push in the cylinder :imstupid: A bunch of oil came squirting out right in my face and all over my hair. Thank goodness it was cold oil. I did not run the tractor prior to this process. that would have been awful if it was hot! Share this post Link to post Share on other sites
JimD 3,347 #2 Posted September 9, 2008 hey mainedad, you should have used brylcream, a little dab'll do ya! seriously, glad you weren't hurt. even cold that stuff would not be good for your eyes. jim in garrettsville,ohio. Share this post Link to post Share on other sites
refracman 167 #3 Posted September 9, 2008 Never had it spray in the ol' mug but had just spray me bout everywhere else. Good to here your OK cause hot oil burns be nasty. Share this post Link to post Share on other sites
kpinnc 15,656 #4 Posted September 9, 2008 Did the same thing with the Bronco 14. It is full of ATF... Kevin Share this post Link to post Share on other sites
hodge 6 #5 Posted September 9, 2008 I did that, too :banghead: Share this post Link to post Share on other sites
