wheeler 5 #1 Posted January 30, 2014 I recently acquired a '73 18-auto with ARK 550 loader. I was considering upgrading the front end with tapered roller hubs, 4 or 5 bolt rims, and 1" spindles as I've seen in some of the posts. I like the spindles from I believe a 520 that have the castellated nuts as setting the preload will be easier. Long story short, when I took my wheels apart, I found 1" spindles. My model in the parts lookup calls out 3/4" spindles, bearings, etc. So what do I have? Were they an option or did someone in the last 40 years upgrade them? There is some play in the wheel along the spindle axis which probably is because there are no shim washers. Just the bolt and flat washer keeping the wheel from sliding off, which is why I thought someone may have swapped parts. Thanks in advance, Carl Share this post Link to post Share on other sites
Marv 994 #2 Posted January 30, 2014 Likely the spindles were upgraded. I redid my D200 front end with tapered bearings and new wheels. is the thread on it. Marvin Share this post Link to post Share on other sites
wheeler 5 #3 Posted January 31, 2014 (edited) Hi Marvin, Thanks for the link to your upgrade. I had seen it before but this time went through it carefully since I now know I have 1" spindles. I think it is the simplest way to make the change for any machine that has the 1" hardware. I assume you used the sleeve bearing to make up for not having the shaft end threaded for a castellated nut. My shaft is 4 1/4" long and the hub claims it is for a 4" shaft, so a spacer/collar and some shim washers should get things snug. Thanks again Carl Edited January 31, 2014 by wheeler Share this post Link to post Share on other sites
pfrederi 19,375 #4 Posted January 31, 2014 M D200 has the 1" spindles, I guess it was a factory option at some point. It is not something done by a previous owner. Share this post Link to post Share on other sites
