rj24 38 #26 Posted January 30, 2014 do you know any thing about this GT 1800 that i don't know about Share this post Link to post Share on other sites
bmsgaffer 2,071 #27 Posted January 30, 2014 do you know any thing about this GT 1800 that i don't know about Well, its hard to say what you don't know... But the collective knowledge of this forum has blown me away. If you ask a specific question in the right section then I'm sure there is someone here that can help you! 1 Share this post Link to post Share on other sites
rj24 38 #28 Posted February 1, 2014 (edited) my stering gear is poping and my shaft has a lot of play up and down on it how do i fix that Edited February 1, 2014 by rj24 Share this post Link to post Share on other sites
Martin 2,134 #29 Posted February 1, 2014 if you have up and down movement in the steering shaft there are a few places to check....... first are we talking about the lower horizontal shaft or upper one that the steering wheel attaches to? lower, two places to look....... there is a replaceable bushing (6397) at the slotted nut end of the shaft and the flanged bushing at the other end is replaceable. (6472) and the upper shaft that the steering wheel attaches to...... i replaced the factory arrangement here with a 6472. under this circled area you would have a cotter pin through the shaft or a locked collar that is used to limit the amount of travel up and down. there are washers to take up the gap here on the shaft. if none, some could be added here or if a locked collar it could be snugged up against the bearing.... usually older well used tractors have a lot of sideways movement here as well. and replacement of the bearing/ fixing of the hogged out hood stand hole is needed. my fix with the 6472 bearing took care of this sideways movement.... Share this post Link to post Share on other sites
rj24 38 #30 Posted February 1, 2014 thanks that will help me out. how about the poping when you tern the wheel Share this post Link to post Share on other sites
Martin 2,134 #31 Posted February 1, 2014 not sure what you mean by poping. do you have noise in the gears? sometimes an adjustment and lube does wonders. after the slop is taken out that is........ Share this post Link to post Share on other sites
rj24 38 #32 Posted February 2, 2014 (edited) what should i use in the workhorse transmission oil the guy i got it of from used universal hydraulic and transmission fluid that is 10w-30 with something in it and toro told me it to use that and you guys told my to use 10w-30 engine oil what should i do or dont it mater any Edited February 3, 2014 by rj24 Share this post Link to post Share on other sites
rj24 38 #33 Posted February 3, 2014 if you have up and down movement in the steering shaft there are a few places to check....... first are we talking about the lower horizontal shaft or upper one that the steering wheel attaches to? lower, two places to look....... there is a replaceable bushing (6397) at the slotted nut end of the shaft and the flanged bushing at the other end is replaceable. (6472) IMG_2902-1.jpg and the upper shaft that the steering wheel attaches to...... i replaced the factory arrangement here with a 6472. under this circled area you would have a cotter pin through the shaft or a locked collar that is used to limit the amount of travel up and down. there are washers to take up the gap here on the shaft. if none, some could be added here or if a locked collar it could be snugged up against the bearing.... usually older well used tractors have a lot of sideways movement here as well. and replacement of the bearing/ fixing of the hogged out hood stand hole is needed. my fix with the 6472 bearing took care of this sideways movement.... IMG_2898-1.jpg thanks the shaft is a little titer now but need to get the bustion fix this summer Share this post Link to post Share on other sites
