redsquarebob 27 #1 Posted January 25, 2014 I was wondering when i put the new fuel pump on if i have to line up anything on the cam or if you can just stick it in there Share this post Link to post Share on other sites
rmaynard 16,549 #2 Posted January 25, 2014 Make sure that the arm is on top of the cam. Share this post Link to post Share on other sites
redsquarebob 27 #3 Posted January 25, 2014 you can see it in there maynard i never put one on before Share this post Link to post Share on other sites
rmaynard 16,549 #4 Posted January 25, 2014 Looking into the fuel pump hole in the block, you will see the cam sitting slightly lower than the hole. The pump lobe of the cam will be to the right. The arm on the pump points downward, and the underside of the arm goes on top of that lobe. On a K181 you can hardly do it wrong. Share this post Link to post Share on other sites
redsquarebob 27 #5 Posted January 25, 2014 Ok thank you maynard Share this post Link to post Share on other sites
