RJMcEachern 18 #1 Posted January 24, 2014 I am trying to figure out why headlights will not work, according to the wiring diagram, I should have a 9 pin engine harness connector, I am having trouble locating this connector, anyone know where it is hidden on the wiring harness? RJMcEachern Share this post Link to post Share on other sites
Sparky-(Admin) 24,769 #2 Posted January 24, 2014 With the hood open look at the space between the engine and the battery. Its in there, worked on mine once (16 Onan) and its a pain. Mike......... Share this post Link to post Share on other sites
RJMcEachern 18 #3 Posted January 24, 2014 Thanks for the info, am i looking for a flat 9 pin or is it square/rectangular/oval shaped? RJMcEachern Share this post Link to post Share on other sites
Sparky-(Admin) 24,769 #4 Posted January 24, 2014 Not flat, more rectangle. We must have a pic around here somewhere. Mike......... Share this post Link to post Share on other sites
Martin 2,133 #5 Posted January 24, 2014 (edited) Here you go It's called a molex 9 pin connector and if you look at the pin end it's square..... Sent from my iPhone using Tapatalk Edited January 24, 2014 by Martin Share this post Link to post Share on other sites
RJMcEachern 18 #6 Posted January 24, 2014 ok, I found it, but I also seem to have an issue with this, so mine is same type, but schematic shows a green wire to light green wire and mine is white, to the bulb connector then green afterwards, and also looks like someone previously bypasses the connector red wire and hard soldered them together... RJMcEachern Wonder if RadioShack would have a 9 pin molex connector???? Share this post Link to post Share on other sites
Martin 2,133 #7 Posted January 24, 2014 Got mine from mouser.com . Got a kit with numerous sizes for around $30. RadioShack might have them, but I doubt they would carry the 9 pin. The wire colors don't always continue the same, from memory there are instances where colors change at those plugs. Wiring diagram will tell you for sure. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
RJMcEachern 18 #8 Posted January 24, 2014 (edited) ok, here is a couple of pics of the connector, just so everyone is on same page Here is the electrical diagram I am working from... RJMcEachern Edited January 24, 2014 by RJMcEachern Share this post Link to post Share on other sites
RJMcEachern 18 #9 Posted January 24, 2014 got it figured out, the switch connectors are corroded and wiggling the wires on the switch male connectors, worked like a champ, one rear light bulb is blown, both front work, need to get some more dielectric grease and contact cleaner then will put it back together...they work tho... RJMcEachern 1 Share this post Link to post Share on other sites
squonk 45,811 #10 Posted January 24, 2014 They use molex connectors on ice machines and furnaces too.They are nothing but junk. Share this post Link to post Share on other sites
RJMcEachern 18 #11 Posted January 25, 2014 (edited) yea i agree squonk! they use em on computers and same thing they are junk. So I bought some CRC QD Electronic Cleaner and CRC Dielectric grease, should be good to go after they get a "treatment"... I usually use De-Oxit, but they were out, anyone have any experience with the CRC product? I have had great experiences with thier other products so I it was my second choice. RJMcEachern Edited January 25, 2014 by RJMcEachern Share this post Link to post Share on other sites
30years 0 #12 Posted January 25, 2014 Contact cleaner: I've had good results with Wurth Contact OL http://www.wurthusa.com/web/en/website/produkte_1/chemicals/cleaners/cleaners.php Recently had a 60A breaker on my generator act up after generator had been stored a while. (one leg not making good contact) While out of service I ran the engine occassionally, but didn't utilize the electrical output end of things. After trying all the local electrical parts dealers for a replacement - with no luck I decided to give the breaker a good dose of Wurth OL. Cleaned it up and it worked fine. Ordered a new replacement breaker, but the Wurth product got me going till it arrived. I've used a number of Wurth products and have been satisfied with all. Share this post Link to post Share on other sites
