AMC RULES 37,195 #1 Posted January 21, 2014 Any parts available for an early Schnacke (K-90) recoil? I'm looking to find a suitable replacement for the pull cable, and recoil spring used on this unit. Any help would be greatly appreciated. Share this post Link to post Share on other sites
Jake Kuhn 1,579 #2 Posted January 21, 2014 get with joe papke, he has most of the stuff. If you mail it to him he can fix it for you. 1 Share this post Link to post Share on other sites
fireman 1,022 #3 Posted January 21, 2014 I have a couple original Kohler pull handle/cables in stock! They are super hard to find and not sure if I really want to part with them. I do know that someone reproduces the handle. Might be Glen. Keep your eye on Ebay for the spring and possibly the other parts. That's where I found these! 1 Share this post Link to post Share on other sites
russtiron 41 #4 Posted January 21, 2014 Try This e bay auction I have purchased this from the seller before 321300025318 1 Share this post Link to post Share on other sites
AMC RULES 37,195 #5 Posted January 21, 2014 Yep, I keep looking at that one. Share this post Link to post Share on other sites
buckrancher 2,694 #6 Posted January 22, 2014 (edited) I have some cables Craig glen makes the handles Brian Edited January 22, 2014 by buckrancher Share this post Link to post Share on other sites
groundhog47 347 #7 Posted January 22, 2014 (edited) Say Craig, I'll see if the one at scrap yard is same (on a Wisconsin engine), has been five days. I'll get back by PM if is that type and still there. Edited January 22, 2014 by groundhog47 Share this post Link to post Share on other sites
VinsRJ 723 #8 Posted January 22, 2014 That is way to much for the recoil... next without experience these recoils are not for the faint of heart. They do require a little know how to take apart and put back together. Also be advised that these recoils are like the worst... they work great for a while and then give up the ghost quick. If the tractor is a runner, I personally would locate a Fairbanks or equivalent. 1 Share this post Link to post Share on other sites
AMC RULES 37,195 #9 Posted January 22, 2014 It came to in pieces, disassembled by the PO. Seemed to me pretty straight forward to reassemble...no problems there. Checked the parts diagram in the gen set manual, seems like it went back together correctly. Rebuilt my other Fairbanks Morse recoil this past summer using a $2 Tecumseh replacement recoil spring from Ebay...worked like a charm. Seems to me like something with similar ends on it would work well in this application too. I'm thinking two dollars...I'll roll the dice, and take another chance. 2 Share this post Link to post Share on other sites
Ken B 3,189 #10 Posted January 23, 2014 I'm with Vin, they are kinda fragile. I've done mine a few times. I get to do it again soon because when I went to start my RJ at the Kent show last yr. the K90 kicked back and in the process one of the ears broke off the pull handle. (I think Vin and Matt got to witness that) The rubber was hard. I got cut from it and it hurt like hell. Give it a shot and try too fix it yourself, that way when it does come unwound at a show you'll be able to fix it yourself. It will probably take you a few times to get it right but you'll learn something new. 1 Share this post Link to post Share on other sites
AMC RULES 37,195 #11 Posted January 23, 2014 Were the internal of these all the same...or are there a couple different models out there? I found some online picts where the dog cup looks different than mine. Share this post Link to post Share on other sites
dclarke 4,082 #12 Posted January 23, 2014 This is what's on my K91, Craig. Looks like there's at least two different models. This is what it looks like when I pull the cable. And this is the nut 2 Share this post Link to post Share on other sites
AMC RULES 37,195 #13 Posted January 23, 2014 for sharing the picts Denny. Yep, yours looks the same as mine...what size is the nut? Seems to be the only piece I'm missing. Share this post Link to post Share on other sites
dclarke 4,082 #14 Posted January 23, 2014 The nut's 7/16" S.A.E. thread. Share this post Link to post Share on other sites
AMC RULES 37,195 #15 Posted January 23, 2014 Perfect, I need one of those. Thank you Denny. Share this post Link to post Share on other sites
buckrancher 2,694 #16 Posted January 23, 2014 nuts are hard Craig you may be able to modify a class 8 coupling nut 1 Share this post Link to post Share on other sites
dclarke 4,082 #17 Posted January 24, 2014 Could you make one from a piece of hex rod (McMaster Carr 6512K43) Then have it hardened? ...........I don't know much about metals, just a thought. 1 Share this post Link to post Share on other sites
AMC RULES 37,195 #18 Posted January 24, 2014 I thought something was up with these units...being that the Kohler manual parts diagram I included in the initial post here shows a two piece drive nut setup. I didn't think that would end up being the correct drive for this unit...which is why I asked if there were more than one version of the Schnacke recoil out there. I'm hoping someone can post here the part number for the correct inch and a half drive nut I'm now searching for? Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #19 Posted January 24, 2014 https://www.partstree.com/parts/?lc=kohler_engines&mn=K91-2739++%284+HP+%283+kW%29+SPECS+2650-31997%29&dn=catalogs_11088 1 Share this post Link to post Share on other sites
AMC RULES 37,195 #20 Posted January 24, 2014 Ahh...there you go...thanks Terry. 1 Share this post Link to post Share on other sites
clintonnut 126 #21 Posted January 24, 2014 Craig, I have those drive nuts and the recoil springs for these starters.... Charlie 3 Share this post Link to post Share on other sites
AMC RULES 37,195 #22 Posted January 24, 2014 Doin' my happy dance over here. PM sent Charle. Share this post Link to post Share on other sites
AMC RULES 37,195 #23 Posted February 24, 2014 (edited) I'm with Vin, they are kinda fragile. I've done mine a few times. I get to do it again soon because when I went to start my RJ at the Kent show last yr. the K90 kicked back and in the process one of the ears broke off the pull handle. (I think Vin and Matt got to witness that) The rubber was hard. I got cut from it and it hurt like hell. Give it a shot and try too fix it yourself, that way when it does come unwound at a show you'll be able to fix it yourself. It will probably take you a few times to get it right but you'll learn something new. Is there one specific weak point that keeps repeatedly breaking Ken...ie; cable, spring, handle? What parts should I keep on hand? Edited February 24, 2014 by AMC RULES Share this post Link to post Share on other sites
VinsRJ 723 #24 Posted February 24, 2014 Basically everything you have stated Craig... If you are going to use the recoil on a tractor that is driven often, I would use a different recoil. Keep the Schnacke for the show machine Like Jake said Joe Papke has all of the parts in stock as well as the nuts. Share this post Link to post Share on other sites
Lane Ranger 11,390 #25 Posted March 10, 2014 These Schnacke's are an interesting recoil setup. I just started investigating the one that was on my RK acquisition from Oklahoma. The three dogs that 'catch" the large hex nut attached to the crankshaft must make a tighter grip, pull then a recoil with a cup on it. But the internal parts, spring, cable and three dog setup seem to be weak in some spots. I have Kohler recoil and cup on one RJ with a K91 motor. This RJ has a K 90 motor and a Schnacke and I may have to take VingRJ's suggestion and put a Kohler type on this RJ as I plan on just working with it -not a show candidate. 1 Share this post Link to post Share on other sites
