Similar Content-
			 By Gcw804 By Gcw804
 I have a WH 300 series with a Kohler Magnum 10 engine and I cannot for the life of me figure out how to get the choke cable and linkage set so it will work. The numbers on the engine label are worn off the, so I cannot give anyone that information. Does anyone have a picture or can you head me in the right direction.
 My arm for the linkage assembly is set at 3 o'clock and 9 o'clock if that helps. There seems to be several different linkage rods for this engine.
 Thanks
 Gary Williams
			 By cJ_3D By cJ_3D
 Hey all!
 Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
 CJ
			 By bkarp@roadrunner.com By bkarp@roadrunner.com
 my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
			 By Tinman1962 By Tinman1962
 Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
