dandan111
Snow Blade/bent
dandan111
My snow blade is warped and the square tube across bottom is bent to sh**. You guys have this problem? It's a 48inch on a 314 WH.
I have taken care of this tractor but my blade can't take it. I'm going to take it to the weld shop in the spring.
smoreau
First take the head off, then wrap a chain from one side to the other. use a car jack between the blade and the chain and it will straiten up the blade. I have bent mine more times then i would like to talk about :hide: But this is how I have fixed mine. Learned how to do it from Kelly :thumbs2:
dandan111
Sounds good. I was thinking about having heavier steel tube put on the bottom. It would add weight though and maybe cause the rest of the blade problems.
smoreau
if one side is worse then the other, just move the jack to that side and it will put more pressure to that side.
AMC RULES
Sould be easy to beef up the blade perimeter with 1x2" box tubing.   :techie-eureka:
dandan111
Just across the bottom AMC? That factory piece on there now looks like C channel spot welded.
Sparky
Wonder how many times it can be straightened before it gets weak? Probably an impossible question to answer (like how many licks to get to the center of a tootsie-pop).
Mike...........
smoreau
I got 3 seasons on my 48" and straitened in the spring every year.The last time I welded up a crack in the c channel. Know that I have the V-blade I haven't used that blade. I have straitened out the bottom ware edge on the V-blade twice this year though.  :hide:  The Ice this year has been BAD for blades. Snow blower has had no problems though.
can whlvr
I put angle iron at the bottom of mine,had to notch it so the trip still works some,but it cant trip all the way so hitting hard objects can be hazardous
