dagwoodz 1 #26 Posted March 22, 2014 Mock up with cub cadet wide frame spindles, 4/8/15 fronts and hi runs on JD wheels out back. Sent from my iPod touch using Tapatalk Sent from my iPod touch using Tapatalk 1 Share this post Link to post Share on other sites
baerpath 517 #27 Posted March 23, 2014 You could narrow up the front by using a B series axle or drop and narrow it with a 200 series axle or a RJ one Share this post Link to post Share on other sites
dagwoodz 1 #28 Posted March 23, 2014 Going to make a tube steel axle. Today was just a look and see. Sent from my iPod touch using Tapatalk Thanks for the info. Sent from my iPod touch using Tapatalk Share this post Link to post Share on other sites
chris11 184 #29 Posted March 23, 2014 Looks good keep up the great work. Share this post Link to post Share on other sites
dagwoodz 1 #30 Posted April 1, 2014 Shopping for some 3.50 x 8 tri-ribs and steel wheels for the front. Any good deals out there? Sent from my iPod touch using Tapatalk Share this post Link to post Share on other sites
dagwoodz 1 #31 Posted April 21, 2014 New front axle Sent from my iPod touch using Tapatalk Frame extender for 52 inch WB. Sent from my iPod touch using Tapatalk Share this post Link to post Share on other sites
dagwoodz 1 #32 Posted December 4, 2015 I ended up trading this horse off. I now have a box of parts that will be a c-120. I am reviving this thread. Or I can start new. Anyway I have the trans apart for inspection. I am going to either seal and fill the diff with grease or rearrange the pinions to create a locked diff. Opinions? We are allowed to move the engine forward but I don't want to mess up the belt angle and use of a stock belt. Any ideas? Will post pics soon. Share this post Link to post Share on other sites
baerpath 517 #33 Posted December 4, 2015 I know some do lock the rears. I've never seen it to be worth a doing. We run lighter oil in the rears (ATF) to save hp for the track. Why make the rear use more up just to move the tractor ? 1 Share this post Link to post Share on other sites
dagwoodz 1 #34 Posted December 4, 2015 Going to run ATF. Thinking if packing the ring gear with grease for a limited slip diff. Share this post Link to post Share on other sites
baerpath 517 #35 Posted December 4, 2015 I wouldn't put grease anywhere in the rear. Having a correctly weighted puller will do way more for you 2 Share this post Link to post Share on other sites
stevasaurus 23,763 #36 Posted December 6, 2015 What's with the grease??? Very bad idea...you may end up blocking the oil getting to the outer axle bearings, and it is not really needed. I think you would do more harm then good. Share this post Link to post Share on other sites
