11honda112 0 #1 Posted January 18, 2014 (edited) Hi i got a 312-8 wheel horse for $400 it has 8" front tires i need 6" tires does anyone know were i can get a set they no longer have them any more and how to set the plow without the adjusting rod 312-8 don't have it like on the c85 thanks Edited January 18, 2014 by TT Share this post Link to post Share on other sites
smoreau 658 #2 Posted January 18, 2014 alot of guys switch out the 6" for the 8" tires and switch the spinals to the shorter ones, I have done this as they look and work better IMPO Share this post Link to post Share on other sites
11honda112 0 #3 Posted January 18, 2014 Does that keep the tires from rubbing the deck Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #4 Posted January 18, 2014 I presume you have the 37" two-blade deck? If that's the case, you will need the 6" front wheels with the 15" tall tires & the matching longer front spindles. (they keep the tractor level when using the shorter tires) By "adjusting rod", I think you are describing the Dial A Height knob that limits the downward travel of the lift lever. Note: Wheel Horse mower decks are designed to rest completely on the ground with the cutting height controlled by the lever on the deck. Check the Vendors section for Kelly's Tractor Salvage or Joe's Outdoor Power for used parts: http://www.wheelhorseforum.com/forum/92-vendors/ ...or you can post a "wanted" ad in the classifieds forum for the appropriate parts. (you'll need 300/400 series 6" front wheels & tires and matching spindles, and a complete Dial-A-Height to fit a 312-8) Share this post Link to post Share on other sites
11honda112 0 #5 Posted January 18, 2014 (edited) Yea 37" deck sd O ok thanks C85 adjusting rod will it fit the 300 series Edited January 18, 2014 by 11honda112 Share this post Link to post Share on other sites
chazm 413 #6 Posted January 18, 2014 WELCOME TO Good luck with your new Share this post Link to post Share on other sites
slammer302 2,156 #7 Posted January 18, 2014 Greater Cleveland Tire has the cheapest tires Ive been able to find I got 2 tires mailed to my front door for 53$ Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #8 Posted January 18, 2014 Here's a link to a representative parts list for the complete Dial-A-Height kit ~ so you know what you'll need: CLICK HERE Your existing dash panels can be modified as needed. Share this post Link to post Share on other sites
11honda112 0 #9 Posted January 18, 2014 Is the 312-8 a good tractor? Share this post Link to post Share on other sites
chazm 413 #10 Posted January 18, 2014 Oh yea.... I have a 314 ,its a solid horse Share this post Link to post Share on other sites
11honda112 0 #11 Posted January 18, 2014 I always had the c series the c85 and the c81 I found the peace $53 Share this post Link to post Share on other sites
11honda112 0 #12 Posted January 18, 2014 I found the peace adjuster for $53 thank u for your help guys whats the biggest deck i can put on that 312-8 Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #13 Posted January 18, 2014 The 312s I had were "most comfortable" with a 42" deck. If you go with anything other than the 37" two-blade you can keep the larger front wheel/tires. Share this post Link to post Share on other sites
varosd 1,185 #14 Posted January 18, 2014 The 312s I had were "most comfortable" with a 42" deck. If you go with anything other than the 37" two-blade you can keep the larger front wheel/tires. Like Terry said. If you just get the bigger 42 rear or side discharge deck, you won't have to change out tires rims etc. any pictures? Share this post Link to post Share on other sites
can whlvr 994 #15 Posted January 19, 2014 if you didn't but the dial parts yet,id ask one of our local parts guys for that too,like tt said in his post check with one of them Share this post Link to post Share on other sites
davedean49 0 #16 Posted January 26, 2014 What parts/ attachments are interchangeable with a 312-8? By that I mean what other series/models can be used with/on a 312-8? Share this post Link to post Share on other sites
