pj1960 11 #1 Posted January 17, 2014 Finally was able to go get my pair of 857s for 150.00 today. They need a little love but are complete except for one deck missing a lot but it will be used for parts. Engines are free so this should be an easy fix to get one running. A lot of you may think this was a great deal but I find myself regretting ever seeing them. It will take a LOT to make one useable. That involves time and money. All belts are rotted. The SGs will need attintion all cables and idler pullys frozen plus who know about the deck driveline. I will have to think hard before dumping them to hopefully get my money back. I think these horses turned out to be "nags". 3 Share this post Link to post Share on other sites
AMC RULES 37,255 #2 Posted January 17, 2014 I still think you stole 'em. 1 Share this post Link to post Share on other sites
608KEB 812 #3 Posted January 17, 2014 They both look in nice shape! Share this post Link to post Share on other sites
pj1960 11 #4 Posted January 17, 2014 (edited) I noticed the deck thats mounted has the front roller ripped off leaving a big hole and the gearbox plugs are rotted duct tape. Who know what may be frozen or wore out. The other deck has a very nice pan complete with the roller. I will give them a chance before giving up. One thing that bothers me is what happened the last time I tried to get a vintage tractor operational. It was a Bolens with a Wisconsin. Everyone told me how great it was. Ended up being the biggest boat anchor ever. Spent a ton on it and still didnt have anything. I just hope this isnt the case with a WH. Never ever again would I own a Wisconsin. That 8 1/4 hp. engine had less power than a worn out push mower. Would almost choke down putting the deck in gear. Then it was so low geared it didnt turn the blades fast enough to cut grass. Edited January 17, 2014 by pj1960 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,534 #5 Posted January 17, 2014 They look nice to me. Glenn Share this post Link to post Share on other sites
KC9KAS 4,746 #6 Posted January 17, 2014 I too think you did OK for $150! You have quite a lot to work with there, so just take your time and work with what you have. Share this post Link to post Share on other sites
pj1960 11 #7 Posted January 17, 2014 (edited) After doing alittle cleaning I feel much better and see plenty of potential using 2 to make one. I have a couple of questions.The tractor with the mower has a bracket sticking out front with a long pin thru ii the other one has no bracket. Whats it for? Whats the small thumb lever left of the shifter?. Note the 10.50 rear tires on the mower tractor. Someone posted here they wouldnt fit due to deck wheels but these do and look good. Edited January 17, 2014 by pj1960 Share this post Link to post Share on other sites
can whlvr 994 #8 Posted January 17, 2014 it appears to me to be a great deal,remember its fairly seldom that a machine(or 2 )of this age wont require some attention,even a lot newer tractors can eat up the cash and plenty of time,but that's what makes this kind of hobby so worthwhile and gratifying,ive had a few tractors over the years and they all turned out great in the end,some needed more $ and time then others,it works it self out in the end,plus wheelhorses are almost allways worth fixing Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #9 Posted January 17, 2014 After doing alittle cleaning I feel much better and see plenty of potential using 2 to make one. I have a couple of questions.The tractor with the mower has a bracket sticking out front with a long pin thru ii the other one has no bracket. Whats it for? Whats the small thumb lever left of the shifter?. Note the 10.50 rear tires on the mower tractor. Someone posted here they wouldnt fit due to deck wheels but these do and look good. The bracket looks like it may have been for hanging weights. The thumb lever to the left of the shifter is the fender latch. Share this post Link to post Share on other sites
19richie66 17,828 #10 Posted January 17, 2014 I would have jumped on them for $150 and never looked back. I would fix one deck and redo both tractors. I say that and I have four of them I haven't been able to work on yet, lol. Take your time....... It will happen. Still a great deal. Share this post Link to post Share on other sites
pj1960 11 #11 Posted January 17, 2014 Yeah I think this will be a worthwhile project. Its a shame they were left outdoors neglected. All in all they are in solid shape. Most things that need attention are idler pulleys and things that need to move that has frozen up. My main thing right now is to clean the points and carb to see if they will start. If I know they will run then it will make the rest seem rewarding. For tractors almost 50 years old they still have many years of use left in them despite neglect and that something you cant buy today. Share this post Link to post Share on other sites
speedyleedy 205 #12 Posted January 18, 2014 I think you got a great deal on them i bought a couple like that that had been setting in a barn for years & they turn out to be great running tractor after i cleaned the carb's Share this post Link to post Share on other sites
pj1960 11 #13 Posted January 18, 2014 (edited) We have a problem. I think the push rod for the points is stuck because I see no movement at all. Any suggestions? Do these old Kohlers require a battery to make spark? The batteries in them are natrually shot and I have been trying to rope turn them to see if I could get any sign of life. Edited January 18, 2014 by pj1960 Share this post Link to post Share on other sites
rmaynard 16,996 #14 Posted January 18, 2014 There isn't a lot of movement on that point push rod, and sometimes it's hard to see. But on the other hand, they do wear down, and the cam can wear as well. Yes, you need a battery for those engines to have spark. Share this post Link to post Share on other sites
pj1960 11 #15 Posted January 18, 2014 Thanks for that. I will invest in a battery soon. I am working on the bare tractor it seems to be in better condition than the mower tractor. That deck thats off is very nice so I think I will use the parts off the attached deck to build a good one. The one thats mounted has a huge hole where a roller was ripped off. Share this post Link to post Share on other sites
oaktown1987 82 #16 Posted January 18, 2014 them decks are hard to come by i would replace the woodruff keys in them with hardened ones the the non hardened ones create to much vibration and cause the cast iron plate to crack Share this post Link to post Share on other sites
oaktown1987 82 #17 Posted January 18, 2014 if u get rid of parts let me know Share this post Link to post Share on other sites
pj1960 11 #18 Posted January 18, 2014 (edited) Once I see everything is gonna go right and I wont need a parts tractor around I will think about parting out or selling the remaining tractor. I have not interest in getting 2 running. Can that rear hitch be adapted to standard sleeve equipment. Edited January 18, 2014 by pj1960 Share this post Link to post Share on other sites
oaktown1987 82 #19 Posted January 18, 2014 they do mow good yes sir Share this post Link to post Share on other sites
Wheel-N-It 2,978 #20 Posted January 18, 2014 You should keep that other tractor. Its always good to have a parts tractor around. If you don't believe me then sell it and find out. Just saying this cause I don't want you to find out the hard way. Share this post Link to post Share on other sites
pj1960 11 #21 Posted January 18, 2014 You should keep that other tractor. Its always good to have a parts tractor around. If you don't believe me then sell it and find out. Just saying this cause I don't want you to find out the hard way. Your probably right. In the end keeping that other ole tractor around would would save lots of money on any obsolete parts I may need. Having 2 identical tractors is one reason I worked so hard to get this deal. Not very often you get lucky enough to find "twins". Share this post Link to post Share on other sites
Killer 2000 Chevy 83 #22 Posted January 19, 2014 I have been looking for a s/g belt guard for a while. Share this post Link to post Share on other sites
oaktown1987 82 #23 Posted January 19, 2014 Me tio Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
pj1960 11 #24 Posted January 19, 2014 (edited) One of the slot hitches has been destroyed by being cut off to mount whatever this piece of junk is. The other is intact except they inserted a piece of flat iron making a drawbar then welding it in place. Will just cut the weld and will be fine. Are these tractors suppose to have a drawbar AND slot lift hitch? Edited January 19, 2014 by pj1960 Share this post Link to post Share on other sites
pj1960 11 #25 Posted January 19, 2014 I cant find a serial no. tag anywhere. Is there some numbers I can use for the Toro MPV? The parts download here on RS is old and hard to read. Share this post Link to post Share on other sites
