Fun Engineer 859 #1 Posted January 16, 2014 I have a c-81 that the previous owner changed the fuel delivery system on. So it's not original. I removed the previously installed system and I'm ready to run the new fuel line but I'm not sure how to route it correctly. It appears that it is routed next to the shift lever but not sure what space in the dash tower it should go through. The color catalog I have shows a pic of the engine but I don't see the fuel line. I'm assuming it runs under the crankcase and between the frame. Not sure where it runs between the dash tower, lift, steering and engine. Would someone either post some pictures from the point of the tank valve to the fuel pump? Or can someone describe the routing. I only want to make one cut in this long piece of fuel line. Thanks Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted January 16, 2014 Here's a few from the closet: Hopefully that will get you started. Share this post Link to post Share on other sites
Fun Engineer 859 #3 Posted January 16, 2014 Thanks Terry. That got me started for sure. Now as I look at the color catalog better it appears that the fuel line may be routed between the cylinder head and flywheel shroud. Hopefully someone else will know for sure. Dave Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted January 16, 2014 Your answers are here: Share this post Link to post Share on other sites
Fun Engineer 859 #5 Posted January 16, 2014 EXCELLENT Terry. Thanks. Just as I thought, right through the shroud. That's a nice looking original tractor. You don't find them in that kind of shape around Michigan. Share this post Link to post Share on other sites
Fun Engineer 859 #6 Posted January 21, 2014 Got it routed and all connected. Works great. Share this post Link to post Share on other sites
chazm 413 #7 Posted January 21, 2014 Just love it when a plan comes together Share this post Link to post Share on other sites
Andy G 7 #8 Posted April 19 I realize this thread is 11 years old now, but I’m wondering if somebody could provide me the pictures of the routing? I have a C 81 that I just picked up, and the fuel line is the last thing I need to get figured out. Thank you! Share this post Link to post Share on other sites
