Fun Engineer 863 #1 Posted January 13, 2014 So I've got this desire to add more lights and a couple of linear actuators but I can't find an accessory line on my 314-A. I know I can add an accessory bar with terminals on it to power up my accessories but what power source do I tap into, that is keyed from the switch to power my accessory bar? Any help would be appreciated. Thanks Dave Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,989 #2 Posted January 13, 2014 Wiring diagram I would add a fused relay that is activated by the pink wire from the accessories terminal on the ignition switch. This circuit powers the gauges. That way you are not adding the load to the ignition switch. Garry 1 Share this post Link to post Share on other sites
Fun Engineer 863 #3 Posted January 13, 2014 Garry Thanks for your help. Sorry I should have been more clear. I've got the newer 314-A. This is my tractors wiring diagram. Would I tie into the pink between the Park Brake and Light Switch or the 15amp pink leasing from the switch to the ACC light? Dave Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,989 #4 Posted January 13, 2014 If you tap into the pink feeding the light switch the 15 amp fuse ahead of that will protect the relay coil. They don't draw much amperage. Then fuse the power supply to the relay high enough to carry the load you are adding. 20 amp and 30 amp relays are easily found. If it takes more than one feed the 2nd coil or more off the output of the first one. Garry 1 Share this post Link to post Share on other sites
Fun Engineer 863 #5 Posted January 13, 2014 (edited) Thanks Garry Another question. I've never used a relay for installing any lights. I've always just provided a fused block and ran the circuit directly from that. Can you help explain what I'm going to need and how they work? I'm assuming they are available in most auto supply stores? I've purchase products from an on-line electrical house before so I could always go that route if I can't find it locally. Thanks for the help. Edited January 13, 2014 by Fun Engineer Share this post Link to post Share on other sites
Fun Engineer 863 #6 Posted January 13, 2014 Garry Thank goodness for YouTube. Just learned how and when to use a relay. No need to further explain. Thanks for your help. Dave Share this post Link to post Share on other sites
KC9KAS 4,746 #7 Posted January 13, 2014 Garry Thank goodness for YouTube. Just learned how and when to use a relay. No need to further explain. Thanks for your help. Dave Just see how educational these forums are! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,989 #8 Posted January 13, 2014 Hopefully you can find something like this http://www.princessauto.com/pal/en/Trailer/30A-Relay-Socket/8080376.p Makes a neat installation. Garry Share this post Link to post Share on other sites
Fun Engineer 863 #9 Posted January 14, 2014 Here's my source. www.allbatterysalesandservice.com Share this post Link to post Share on other sites
