wheelhorse66 10 #1 Posted January 11, 2014 Can I take the flywheel and generator of a k161 and put them on a k181?will everything fit right? Share this post Link to post Share on other sites
WH nut 553 #2 Posted January 11, 2014 I believe you can as long as you have the bearing plate for battery ignition Share this post Link to post Share on other sites
rmaynard 16,549 #3 Posted January 11, 2014 It depends on what the spec numbers are of both engines. Different spec numbers sometimes = different flywheels. Share this post Link to post Share on other sites
