formariz 12,354 #1 Posted January 10, 2014 Does anyone habe pics of the correct way to route fuel line to pump on a 1981 C-105? Thank you Cas Share this post Link to post Share on other sites
chazm 413 #2 Posted January 10, 2014 Sorry no pics, but it should run from the fuel tank across the trans on the left side of tractor. I ran mine in loom & secured with tube clamps in this area. then along frame to under left side of engine to pump. Hope this gives you some idea of how it goes. I'm sure someone will offer some pics for ya, Good luck Chasm Share this post Link to post Share on other sites
Kelly 1,037 #3 Posted January 10, 2014 from the tank up the right side of the console past the shifter, through a rubber grommet in the lower dash, under the batt tray there is a piece of flat stock with the end rubber coated it gets rolled around the hose to hold it in place, then it goes to the left side of the engine, through metal loops bolted to the blower housing under and up in front to the pump, I hope this is clearer than it is to me after typing it. Share this post Link to post Share on other sites
chazm 413 #4 Posted January 10, 2014 Some pics from my 316 Chasm Share this post Link to post Share on other sites
formariz 12,354 #5 Posted January 11, 2014 thank you guys. Share this post Link to post Share on other sites
