Dieselcowboy 211 #1 Posted January 8, 2014 Will the 520-8 rear lift cable fit over onto a 96'H ? I searched parts tree hard but could not find the # on the H. Found the tube for the 8. Any insight will be great. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,757 #2 Posted January 8, 2014 One of the ipl's for the 1996 tiller model 79370 show both tubes. Garry Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #3 Posted January 8, 2014 The cable is the same. The difference is in the clevis where the cable attaches to the lift lever shaft arm. Hydro models need a longer clevis because the "dogleg" tube shortens the effective length of the cable. The tube is normally already installed from the factory and stays with the tractor. Share this post Link to post Share on other sites
Dieselcowboy 211 #4 Posted January 9, 2014 Cool deal fellas. I have the loader on the 8 and will never use the manual lift. The hydro is the chore tractor. Hoped to swap them around. Will the cable come through the tube? Or does the whole tube have to be changed? By what you've already said it sounds like the tube will stay and cable can be removed in 1 part. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #5 Posted January 9, 2014 As long as no critters have called the tube home, the cable will push through. Share this post Link to post Share on other sites
