Stigian 1,234 #201 Posted May 17, 2014 I don't know how I have missed this!! Sorry James A fantastic job mate, the 3 point is looking good Share this post Link to post Share on other sites
diggerjames 64 #202 Posted May 17, 2014 Cheers Ian I've used a lot of yours and meadowfields plans to build this couldn't of done it with out your videos! Cheers James 1 Share this post Link to post Share on other sites
diggerjames 64 #203 Posted May 28, 2014 Hi all progress has been a little slow but I've had a push today on the linkage which is a work in progress might have to change things as I get using it but I've never done one before so it's trial and error . I've been fabricating the top link bracket plate Share this post Link to post Share on other sites
rtfbg 744 #204 Posted May 28, 2014 DJ ... really like to looks of those TIRES, (spelled correctly!! lol) Share this post Link to post Share on other sites
diggerjames 64 #205 Posted May 28, 2014 It spelled tyres mate Lol Share this post Link to post Share on other sites
rtfbg 744 #206 Posted May 28, 2014 Hey .. we won the war!! It's TIRES!!! lol Share this post Link to post Share on other sites
rtfbg 744 #207 Posted May 28, 2014 Just remember, MATE ... if it wasn't for us, you would be spelling it REIFEN !!!! 1 Share this post Link to post Share on other sites
rtfbg 744 #208 Posted May 28, 2014 (edited) Hey, just saw this posted on ebay, maybe the pic will give you some ideas??!! Edited May 28, 2014 by gulftane Share this post Link to post Share on other sites
rtfbg 744 #209 Posted May 28, 2014 Here's another idea for your center link ... a little choppin and weldin and this could work!! Share this post Link to post Share on other sites
diggerjames 64 #210 Posted May 30, 2014 Cheers mate good idea Share this post Link to post Share on other sites
rtfbg 744 #211 Posted May 30, 2014 Hey DJ ... where your hitch is going in the frame brace (don't know a better name) the brace has two sides about an inch apart. Is yours going to float in that space on a bolt, or are you using bushings to fill it??? I am making a winch bracket to go in the same place ... haven't figured it out yet!!! Share this post Link to post Share on other sites
Olratlr 25 #212 Posted June 1, 2014 Good Luck with the D200 James make it pretty ha. Share this post Link to post Share on other sites
the_nite_owl 15 #213 Posted June 2, 2014 It spelled tyres mate Lol Oh, do'nt listen to him. Spell it the way you want. The U.S.A. is the one responsible for adding the word axed to the dictionary as slang for asked so I do not think we qualify to be a source of criticism over language. Tires and Tyres is pronounced the same way so no big deal. It is when the pronunciation changes that throws me. I just cannot get used to aluminum (aluminium). I like your pronounciation but just feel too silly saying it so... Nice work on your resto. I have a D160 I am doing a partial restoration on. Any chance you could take a snapshot of where your starter relay is mounted? Mine appears to be in the correct spot but the brake linkage comes into contact with it shorting out the battery. Share this post Link to post Share on other sites
the_nite_owl 15 #214 Posted June 2, 2014 I do not need a picture of the mounting location for the starter relay after all. The relay had been replaced with an aftermarket relay and did not fit correctly. I swapped it out with an NOS one I found and that cleared up the problem. I ended up moving the mounting holes for it back an inch though to give me clearance for a rod going to a foot pedal I am putting in for forward/reverse control. I hope to get that wrapped up today and finish working on the loader so I can put this all back together. Share this post Link to post Share on other sites
muz123 1,193 #215 Posted November 15, 2014 looks fun Share this post Link to post Share on other sites
3WHDave 60 #216 Posted April 27, 2020 This is a new response to an old post... I’m restoring a D180 and like many, my oil temp gauge has a broken needle. The plastic was not UV stable and deteriorated to the point of near-powder. I see many posts on oil pressure, but not on temp gauges. I did disassemble the old gauge and it appears to be fine (removing bezel is a pain, slow going expanding crimp). Is there an. OEM, or near OEM source? Again, all suggestions are appreciated. PS: engine reasonably going well, may fire it up with temp gas tank, mine is out for paint sand blasting. Last resort: 3D print a needle. Share this post Link to post Share on other sites
JamesBe1 84 #217 Posted May 3, 2020 Hi Dave. Since none of the more knowledgeable members has replied, I thought I'd add my humble opinion. I suspect that you can probably find a needle off a newer style donor gauge. There are lots to choose from. I'm sure you don't want to overspend on such a small part. You might check out ebay for good used gauges, and pick one up cheap. You might even find a working temperature gauge if you wait around long enough. If you have the PN, you might want to search the web for it. No telling what might turn up. There are lots of people with stashes of miscellaneous parts that might have the whole gauge at a reasonable price. You might also consider just replacing the whole gauge. I'm pretty sure that the diameter is standard. When I added a pressure gauge to my D-180, there were several types to choose from in the diameter I needed. I'm sure the same goes for temperature gauges too. Good luck and let us know what you come up with. Share this post Link to post Share on other sites
