diggerjames 64 #176 Posted April 8, 2014 After reusing the original head lights which both worked one of them blew I was going to use LEDs but It wouldn't looked right so I've done some digging in my mates part stores who like my self restore old tractors especially David brown and Case International and has look would have it they are exactly the same as db 990 ,885 etc. I've put on the original box on for part no reference hope this helps anybody cheers James Share this post Link to post Share on other sites
meadowfield 2,955 #177 Posted April 8, 2014 they are really standard units, two a penny in the US - I brought two units back with me a few years ago. Over here still standard, but a bit pricier. They are easy to find in the rubbolite type assemblies used on plant equipment Share this post Link to post Share on other sites
leereynolds 0 #178 Posted April 11, 2014 I need the quick coupler to a D200 for my tiller. I cannot find the part, is it an option to drill and pin on the spline? Share this post Link to post Share on other sites
wheeledhorseman 579 #179 Posted April 11, 2014 Those head lights look fine James. To put prices in perspective, as a Toro / Hayter part they were about £18 each a couple of years back when I was doing my first D. In the US as a GE lamp rather than Toro part they were about $5 each. As I had had three tractors using them at the time, four now, I decided to import a box of ten which ended up costing me just under a tenner each including shipping and import duty. I thought it would be a lifetime's supply but I'm down to just a couple now so may do it again. The odd thing about the GE bulbs is that they are 12 volt rated as opposed to 14 volt and in the GE spec the life expectancy at 14 volt falls dramatically to just a few hundred hours though of course they run brighter. They also seem to crack easily at the back, not a problem with the rubber mountings used on a D series but it's an issue with the 300 series tractors etc where a metal tab holds the unit in place. If it's anything but a light pinch to secure the lamp then after extreme cold in winter you can find the glass has cracked. Andy Share this post Link to post Share on other sites
diggerjames 64 #180 Posted April 12, 2014 Thanks Andy it's booked in for its first show at the end of this month still plenty to do At the akworth Scammell Gathering ! Share this post Link to post Share on other sites
diggerjames 64 #181 Posted April 12, 2014 Hi all had a good day today fitted the new decals today which I got from Mark ( meadowfield ) and I must say they realy set the tractor off many thanks mark Cheers James 1 Share this post Link to post Share on other sites
meadowfield 2,955 #182 Posted April 12, 2014 Awesome work! Looking forward to seeing it Share this post Link to post Share on other sites
fabricator2009 48 #183 Posted April 13, 2014 Wow, that looks good. Share this post Link to post Share on other sites
diggerjames 64 #184 Posted April 13, 2014 Hi all my mate paul Dibnah had had my fuel tank for a bit of specialist repair work and he's made a cracking job Share this post Link to post Share on other sites
rtfbg 745 #185 Posted April 13, 2014 You're way ahead of me James ... my teardown is complete ... and my first step of rebuild is just finished ... since I'm doing man 18" frame stretch, the first thing I had to do was stretch the drive manifold. Got it back from the welder today ... all set for install, but the frames not ready yet!! Will connect these halves with soft line once they are in place. 1 Share this post Link to post Share on other sites
diggerjames 64 #186 Posted April 13, 2014 Looking good mate u have took yours one stage further than mine total strip down good luck with it bud Share this post Link to post Share on other sites
rtfbg 745 #187 Posted April 13, 2014 Thanks ... bit of a wait now, the frame is at the weld shop, he has the 1/8th material for the bottom section, but the top side frames are 3/32, and he had to order that, so we wait!! 1 Share this post Link to post Share on other sites
wheeledhorseman 579 #188 Posted April 15, 2014 Looking good with the decals there James! Enjoying watching the progress on yours too gulftane. Andy 1 Share this post Link to post Share on other sites
diggerjames 64 #189 Posted April 19, 2014 Hi all finally got the D out and I made a short video hope you enjoy 4 Share this post Link to post Share on other sites
rtfbg 745 #190 Posted April 22, 2014 Hey ... any of you D guys have a complete scrap parts machine??? I need a front cover, 101911 ... almost looks like a crossmember. Previous owner must have done some plowing ... without a plow!! lol I have beat on it for an hour and it's not gettin straight!! Share this post Link to post Share on other sites
diggerjames 64 #191 Posted April 24, 2014 No mate the D series is extremely rare over here and parts more so good luck with the build Share this post Link to post Share on other sites
Desko 645 #192 Posted May 13, 2014 Is the restoration finished? Thanks for sharing. Share this post Link to post Share on other sites
rtfbg 745 #193 Posted May 13, 2014 FINISHED??? I love you man!!! Hell no!!! Not even done with the frame stretch yet, still cleanin parts and looking for replacements. Probably another 2-3 weeks B4 I start putting it together!! bob Share this post Link to post Share on other sites
diggerjames 64 #194 Posted May 13, 2014 No mate it's not done yet just designing and building a 3 point linkage ! Thanks for your comments guys Share this post Link to post Share on other sites
diggerjames 64 #195 Posted May 15, 2014 Hi all over the last few days I've been planing and building my three point linkage , I've been using ideas from various people to name a few Stigian and Meadowfield cheers guys these are the lift arms I've fabricated out of old fergy bars Share this post Link to post Share on other sites
meadowfield 2,955 #196 Posted May 15, 2014 looking good!!!!! Share this post Link to post Share on other sites
rtfbg 745 #197 Posted May 15, 2014 (edited) Hey gang ... another PITA question for you!!! My D has the Kohler engine, with NO stickers or markings visible. When I tear it down, is there anywhere else on it that I may find the model and serial number?? Edited May 15, 2014 by gulftane Share this post Link to post Share on other sites
rtfbg 745 #198 Posted May 15, 2014 Ready for ..... ALSO NOTE, I am going to sell all of the mower parts, including the front PTO assy and controls. 1 Share this post Link to post Share on other sites
bmsgaffer 2,069 #199 Posted May 15, 2014 Hey Gulftane, You should probably start your own D200 restoration topic. You are just in the thick of it and digger (the owner of this post) is at a different point. It will help us follow along yours better! Its hard to follow two different restorations in one thread. Looking forward to it! 2 Share this post Link to post Share on other sites
diggerjames 64 #200 Posted May 17, 2014 Hi all I've been busy the last couple of days cutting and grinding and welding to make my three point linkage here is what I've done so far 2 Share this post Link to post Share on other sites
