TravelinJavelin 620 #1 Posted January 6, 2014 well I'm still thinking and as much as I would love t do a hydraulic set up is going to be to expensive for right now and leaning towards a winch mount set up so if I went that route I would have no need for a lift flag right? as long as the winch is front mounted correct? still looking for more pics and idea's on this too Share this post Link to post Share on other sites
decksetter 50 #2 Posted January 6, 2014 Where would you mount the winch? I'm not sure how this would work, as there isn't anything solid enough up front to mount a winch to that will be high enough to actually lift it. Sent from my DROID RAZR using Tapatalk Share this post Link to post Share on other sites
SCOOBY 312-h 14 #3 Posted January 6, 2014 if you found a way to mount a small winch to the atachamatic i wouldnt see why that wouldnt work, or take the mower mule drive and mount the winch to the front of that? Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted January 6, 2014 if you found a way to mount a small winch to the atachamatic i wouldnt see why that wouldnt work, or take the mower mule drive and mount the winch to the front of that? But then where you attach the thrower? Perhaps a rear-mounted winch with some pulleys and a bellcrank / Z bar under the tractor frame to turn the winch pull into a push and raise the thrower using a modified lift tube? 1 Share this post Link to post Share on other sites
Wishin4a416 2,191 #5 Posted January 6, 2014 There was just a recent thread where a fellow made a raised mount on the frame and added a winch to lift implements. But i forget the name of the thread and where it was. I search around for it later. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #6 Posted January 6, 2014 Was it Lars? Share this post Link to post Share on other sites
Wishin4a416 2,191 #7 Posted January 6, 2014 Was it Lars? Thats the one I was referring to. Thanks TT 1 Share this post Link to post Share on other sites
TravelinJavelin 620 #8 Posted January 6, 2014 yeah I saw that but I just don't want to alter the battery placement that's all my thought was to tackweld a ring on the blower, build a tower winch mount with some pins to deattach if you had to get under the hood, I admit there would be some measuring involved for clearances to lift the blower, but anyways just a thought the other system is a killer set up just wish there was a way to keep the battery under hood Share this post Link to post Share on other sites
Ed Kennell 42,070 #9 Posted January 7, 2014 Does your blower mount to the Tach-a-matic or to the outside of the frame. I have both and am planning to build a winch post to lift the frame mounted blower. It would attach to the Tach-a-matic and come up between the blower side plate frame bars. It could easily be lowered to open the hood or removed completely by releasing the Tach-a-matic. If you do install a winch, put a strong spring in the pull line , because the winch overrun will break something . HF has a 2500lb remote control winch on sale now for $50. I have this arrangement on my 4 wheeler to lift a plow, and It has worked well for several years. Share this post Link to post Share on other sites
can whlvr 994 #10 Posted January 7, 2014 sorry no pics of this but I put a winch in the middle of my 308,it has a pull start and no battery so I mounted it in the middle for the lifting the plow,I made a homemade jonny bucket and needed the winch to lift it,it worked good but if I were to do it again id take a lot of the cable off and only use what I needed about 3-4 feet tops,the extra cable would bind up the pull line and id have to un tangle it Share this post Link to post Share on other sites
pfrederi 18,695 #11 Posted January 7, 2014 With a helper spring the manual lift isn't that bad...is it worth all this other fooling around??? Share this post Link to post Share on other sites
TravelinJavelin 620 #12 Posted January 7, 2014 well my shoulders are worn from pulling hoses over 100' to houses working for fuel companies over the years and just would like something on the effortless side, if I had a small driveway I could get away with it but mine is about 100' long maybe a little longer by 50' squared between the house and garage area Share this post Link to post Share on other sites
Joefrommi65 18 #13 Posted March 4, 2014 My buddy frome work had the same problems with his shoulder he added an extension to his lift handle and he said it made a world of difference. Just a thought. 1 Share this post Link to post Share on other sites
shorts 182 #14 Posted March 5, 2014 could you mount a winch to the mid attachmatic and use it to pull forward on the flag to lift the plow? use as little cable as possible and a pulley at the flag, 2/1 reduction, to help slow the winch down Share this post Link to post Share on other sites
