charging10 261 #1 Posted December 26, 2013 does anyone happen to know the oil capacity for a suburban 5010 transmisson? thanks Share this post Link to post Share on other sites
AMC RULES 37,250 #2 Posted December 26, 2013 Manual call for 3 pints, SAE 90 wt gear lube. Share this post Link to post Share on other sites
stevasaurus 23,516 #3 Posted December 26, 2013 (edited) It will take somewhere between 1 and 1 1/2 qts of 90wt. There is a check plug on one of the side plates near the back axle (I think on the left side). Take off the seat and fender pan, fill through one of those bolt holes until the oil starts to come out the check plug hole. That is the proper level. There is no drain plug on the bottom of the transmission. Just take out one of the bottom bolts holding the plate to the casting and jack up the tractor to aid in draining toward the bolt hole. Edited December 26, 2013 by stevasaurus Share this post Link to post Share on other sites
