gottahavvitt 0 #1 Posted September 3, 2008 I just started tearing down the K241 motor off my 1057 and noticed that only 2 bolts are holding the motor to the frame so I did some research and found that it does indeed have the right motor. My question is Why are there only 2 bolts holding the motor to the frame?? The two bolts are on the flywheel side and the other two holes hang out over the edge of the frame by about 1/2 inch from frame to center of mounting bolt holes. I was just about to unbolt the oil pan to see the damage to the connecting rod and a thunderstorm suddewnly appeared so I an stuck inside for the time beeing. (my shop is too crowded with Harleys to get the tractor inside.) I removed the head though and the cylinder walls look almost new with no ridge or scratches or scuffs so I am hoping to get lucky and just replace the rod and rings. Can someone tell me the answer to the bolt question?? Thanks :banghead: Share this post Link to post Share on other sites
Kelly 1,037 #2 Posted September 3, 2008 There are 2 bolts that screw into the bottom of the pan, did you take the motor off? if you did look at the bottom and there should be 2 theaded holes. Share this post Link to post Share on other sites
gottahavvitt 0 #3 Posted September 3, 2008 My Webpage There are 2 bolts that screw into the bottom of the pan, did you take the motor off? if you did look at the bottom and there should be 2 theaded holes. I have not taken the motor off the frame yet. The two holes I am talking about are actually in the oil pan but they just hang over the side of the frame rails. Here is a picture to make things a little clearer. Share this post Link to post Share on other sites
Kelly 1,037 #4 Posted September 3, 2008 Those holes are not used. there are two on the bottom, that go though the frame Share this post Link to post Share on other sites
gottahavvitt 0 #5 Posted September 3, 2008 Those holes are not used. there are two on the bottom, that go though the frame :banghead: Share this post Link to post Share on other sites
