Ed Kennell 43,152 #1 Posted December 24, 2013 I redid my 1970 model 5-1423 SD 42" deck, and now I can't remember which hole the bolt #47 goes in on the rear lift bracket. The parts assembly shows it in the middle hole. Also does the curved lift channel go above or below the #47 bolt ? The parts dwg. doesn't show this detail. It also appears the lift channel is incorrectly marked # 24 part 6694 washer on the dwg. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted December 24, 2013 I'm pretty sure the pin goes through the middle hole. The tail of the mounting carriage should be on top of the pin. 1 Share this post Link to post Share on other sites
Ed Kennell 43,152 #3 Posted December 24, 2013 Terry, and Merry Christmas Ed Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted December 24, 2013 You are quite welcome..... and MERRY CHRISTMAS to you & yours! Share this post Link to post Share on other sites
Matthieu 0 #5 Posted February 4, 2014 Hello, I'm new from Belgium I'm trying to repair a old ranger A800 For this I need to know the recommended lenght for the belt between engine and mower? Is ti possible to help me? Thank you Share this post Link to post Share on other sites
Matthieu 0 #6 Posted February 4, 2014 If you have right tips; isit possible to send me by email at matthieuvermeulen@outlook.be Thank you very much. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,757 #7 Posted February 4, 2014 The deck was originally a 32 inch width of cut side discharge. Here is the parts list 104388 drive belt is 1/2" x 55" 6855 spindle belt is 1/2" x 55" Not often they are the same size. Garry Share this post Link to post Share on other sites
