grinchsr 657 #1 Posted December 23, 2013 (edited) Hey guys, I'm looking to fit Carlisle All Trail tires 23x10.50-12 on my 1996 312-8, which I think has 7" rims? I've put this size tire on my 1985 312-8 with no issues, but they were two ply more forgiving tires vs the 4 ply massive All Trails. Here is link: http://www.powersportsplace.com/parts/crr-511505/overview/ Thoughts? Edited December 23, 2013 by grinchsr Share this post Link to post Share on other sites
varosd 1,185 #2 Posted December 23, 2013 Looks like you will need the rims off a later year 520 or a Workhorse 18 hp. they have the wider rim you would need. Share this post Link to post Share on other sites
grinchsr 657 #3 Posted December 23, 2013 THANKS DON. I HAD THE FEELING THEY MIGHT BE OVERKILL Share this post Link to post Share on other sites
Chevydave 25 #4 Posted December 23, 2013 If you run a 42" deck the wider rims and tires will rub on the mower wheels. I bought a set and ended up putting chains on them for other uses. The rubbing wasn't real bad but it was marking the tires. Share this post Link to post Share on other sites
oaktown1987 82 #5 Posted December 25, 2013 They will work I've got 10.5 wide tires on 7" wheels really should use wider wheels though Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
oaktown1987 82 #6 Posted December 25, 2013 Did wheel horse ever make a 10.5 wheel Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Kelly 1,037 #7 Posted December 26, 2013 I have a set of those all trails on 520 8.5" rims and its a perfect fit, and I have never seen a factory set of 10" wide WH wheels widest I know of is the 8.5" Share this post Link to post Share on other sites
grinchsr 657 #8 Posted January 3, 2014 THANKS EVERYONE. I WENT WITH THE 9.50'S WITH NO PROBLEM. Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,527 #9 Posted January 4, 2014 I wanted to put those all trail tires on my 1988 416-8. I run a 42 SD cutting deck and wasnt sure of clerance issues????? I really like the profile of those tires. Glenn Share this post Link to post Share on other sites
