1989520HC 13 #1 Posted December 22, 2013 I just picked up this 312 today.This is like a 1994 Magnum. it is missing the end of the starter. it looks like a nut threads on. It keeps the gear from coming off the end of the shaft? Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted December 22, 2013 See if this helps: http://www.partstree.com/parts/?lc=kohler_engines&mn=M12-471546+WHEEL+HORSE+%2812+HP+%289.0+kW%29+SPECS+471500-471583%29&dn=catalogs_31325 Edited to add: Make sure you check for loose / missing parts inside the blower housing. Share this post Link to post Share on other sites
1989520HC 13 #3 Posted December 22, 2013 Thats going to be my next move. Those parts have to have gone someplace. That picture isn't much help. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #4 Posted December 22, 2013 That picture isn't much help. Did you zoom in? drive pinion spring seat spring flat washer nut dust cover Share this post Link to post Share on other sites
1989520HC 13 #5 Posted December 22, 2013 Figured out how it works.....im stupid sometimes. That part is no longer available.... Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #6 Posted December 22, 2013 What do you need? There are aftermarket drive kits available - along with OEM drives on eBay, etc. Share this post Link to post Share on other sites
1989520HC 13 #7 Posted December 22, 2013 Im going out to pull it apart. I will let you know. Thanks Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #8 Posted December 22, 2013 Have you ever removed a starter from a Magnum single? The mounting bolts can twist off easily - and they are also what hold the starter together. Share this post Link to post Share on other sites
1989520HC 13 #9 Posted December 23, 2013 I have never done it before. The way this day went im sure it will snap them off like a twig....The starter drive is what I need.I have a local parts house that is a Kohler dealer. I will see if they can help. Share this post Link to post Share on other sites
1989520HC 13 #10 Posted December 24, 2013 What is the trick to getting the bolts out? I called around today. They wanted $130 for just the drive or $188 for a complete starter. Who makes a aftermarket one? Share this post Link to post Share on other sites
rmaynard 16,884 #11 Posted December 24, 2013 Check eBay. There are a couple of M12 starters for around $54.00 with free shipping. Share this post Link to post Share on other sites
