Raider69 101 #1 Posted December 21, 2013 Hi all, new member here. I have '75 B-100 that I use to move snow, I have both a blade and a snowblower As I get older raising the blower is getting harder and harder. Assuming it is possible I'd like to add hydraulic lift to it, what years and models should I be looking for as parts donors? Or should I just shop for another tractor that already has hydraulic lift? Problem is I don't have room for another one and while the B-100 has LOTS of "patina" it runs great and is kind of a family heirloom. My cousin gave it to me not long before he passed away.Thanks. Share this post Link to post Share on other sites
Kelly 1,036 #2 Posted December 21, 2013 If the tractor is a hydro yes it's a bolt on same trans as the C-120, and 160 except the B-100 has 1" axles (my son has one) you can find all the parts off one of those tractors, it is best to pull it your self or have someone that knows pull it so you get everything, the little stuff that is over looked, extra foot rest bracket, spacer on the bar the cyl goes in, grommets to protect the hoses if still there, and most important the check valves in the trans to make the lift operate. Share this post Link to post Share on other sites
KC9KAS 4,745 #3 Posted December 21, 2013 Raider69, , and Share this post Link to post Share on other sites
Racinbob 12,508 #4 Posted December 21, 2013 I'm thinking, if you have a manual tranny, a lift such as the HY-3 would adapt easily. Then there's the electric lift option that is easily installed. Share this post Link to post Share on other sites
Forest Road 595 #5 Posted December 21, 2013 If its not a hydro some guys have use ATV winches. Share this post Link to post Share on other sites
Raider69 101 #6 Posted December 21, 2013 Thanks all, it is a hydro. here are a couple action shots from the big snow a couple years ago, Even the mighty Horse couldn't bust through the big drift and pile from the state plows at the end of the driveway though. Had to have an end loader finish the job. 1 Share this post Link to post Share on other sites
dodge78 94 #7 Posted December 23, 2013 If you are close to me, I have a 71 bronco 14 parts tractor with that setup on it. Share this post Link to post Share on other sites
608KEB 812 #8 Posted December 23, 2013 If you don't have a manual, I would suggest printing the 1975 C- series manual from this site. Page 17 explains how to disconnect the hydro-lift. Just reverse the process. Share this post Link to post Share on other sites
