oldlineman
throttle cable
oldlineman
Trying to figure out what throttle cable my WH takes. Jacks showes a #115854 and a 115392. This is a 1989 414-8, 3114K804, 35323,9257. Any help would be welcome from the experts. Thank You
gwest_ca
I think the original throttle cable number is 115392 and still available $47.60 at PartsTree but they came out with new ones.
and
98-4329 is new throttle cable and still available for $55.53 at PartsTree.
99-3745 is a choke and throttle kit still available for $127.94 at PartsTree
What is wrong with your cable? Shop around.
Garry
TT
115854 has an outer housing length of approximately 37"
115392 has an outer housing length of approximately 55"
oldlineman
Thanks guys, my cable is running rough and tight am trying to get liquid graphite down inside but was looking for new one if that does not work.Jacks price is $30.06 for 115854 and $40.24 for 115392.I will continue to put graphite down cable and see if that helps.As always thank you for your quick and knowledgeable responses.Great info. source
doc724
Was the cable always this way or did it just start?  For years, I would always wash my tractor in early November and invariably some water would get inside.  If it did not freeze solid in the middle of the winter, it was a miracle.  Many a time I had a light bulb hanging on the cable to thaw out the ice so I could plow.  I finally relented and bought a new cable and the problem was fixed.  Even with no ice, the metal core inside the cable would rust and the inner cable would bind.  The new cables had a seal over the end where it attaches to the carb to limit any water getting down inside.
oldlineman
Its on my summer tractor and I was in the shed today and thought I would fire her up and let her warm up. Pushed the throttle cable and bent the wire inside. Straightened it but think it will want to bend there again. Will try more graphite and see what happens. Thanks for the info.
TT
Many "good" OPE dealers / small engine shops stock various diameters of the inner wire and outer cable housing.
I would try replacing the inner wire first. It should only cost two or three dollars at the most.
Here's a video of a quick & easy way to put the "Z" bend on the end of the cable:
oldlineman
Thanks Terry that will be an option if it will not free up.Thanks Again and have a safe and MERRY (CHRIST)MAS. Remember the reason for the season.
