tomtractor 71 #1 Posted December 17, 2013 Hello all, I was wondering how other people prevent their WH from sliding while plowing. Do people use chains, bike chain, studs, etc... on their FRONT TIRES? I currently have wheel weights on the front and rear. Also chains on the rear tires. The front seam like they need something. It is really annoying when I have a load of wood to have now control over steering! Thanks and have a great holiday season. Tom Share this post Link to post Share on other sites
sorekiwi 761 #2 Posted December 17, 2013 There are quite a few posts here suggesting the use of a piece of roller chain around the circumference of the tire. Apparently this works well, but I've never tried it. I use skinny tri-ribs on the front of mine, 100% better than the wider turfs. Share this post Link to post Share on other sites
Ken B 3,189 #3 Posted December 17, 2013 Tri ribs will really help. You might also want too add some fluid to the front tires.. What model tractor are you using? Share this post Link to post Share on other sites
Hodge71 665 #4 Posted December 17, 2013 I think a lot has to do with the amount of tread depth the tire has. I have heard tri-ribs are much better but I have had good luck with Carlisle Turf Savers that have more than half tread depth. My Charger 12 has them with less than half…ok so maybe its closer to bald and they slide something fierce. The Turf Master by Carlisle does much much better. I have them on the front of the 18 Automatic and I cannot get it to slide no matter how much of a head of snow I am pushing with it. I am very happy with them and will be putting them on the front and rear of the C-160 and the Charger 12 as well next spring Share this post Link to post Share on other sites
leeave96 490 #5 Posted December 17, 2013 I use front cast iron wheel weights and have had good luck with those. Share this post Link to post Share on other sites
lobo 22 #6 Posted December 17, 2013 I was going to try the roller chain idea this year but ran onto a pair of chains that fit the front of my C-100, they did rather well the other day clearing the lane. Have got a piar of weights but need to have them machined some before they will fit the way I want. Share this post Link to post Share on other sites
953 nut 60,070 #7 Posted December 17, 2013 Tri Ribs! Share this post Link to post Share on other sites
Tankman 3,523 #8 Posted December 17, 2013 Driving slow enough, sliding not too much of a problem. How's 'bout weights on the plow (snow blade) itself? Share this post Link to post Share on other sites
gomer gump 8 #9 Posted December 17, 2013 on my 312,416 use front wheel wts on my 520 don,t use anything skidding 99% of the time is usually operator trying to push too darn much . unfortunately wheel horse did not have a 4 wh drive system wish they did . just back up an take a lighter cut an go in a lower gear , steer straight and lift up attachment when in reverse . wheel horse is only a garden tractor with 2 wheel drive aint gonna perform miracles , wish it could also I found putting more air psi in tires helped and a good set of tire chains not the cheap ones also rear wheel wts help . I,ve got hvy cast wts on all my tractors except mowing ones . tri ribs I found was great in mud an dirt but not so great in snow. also a lot a guys forget most wh tractors the steering is wore out from years of use ,I put new steering on a lot of my tractors from the steering wheel to the wheel bearings replace everything with new parts not used ,you will find it will make a hell of a difference . just rebuilt a 416-8 put all new parts on steering steers like a dream .just don,t buy used when it comes to steering ,you will have a lot of slop . doing the roller chain thing I don,t think is the answer but if it helps use it ,I wouldn,t waste my time or money on that. toro does still make a front weight kit that mounts to the fwd frame area got them on mine does help some . best bet don,t try to over load pushing or hauling wheel horse,s will handle a lot but when your skidding your doing more than it can handle. good luck Share this post Link to post Share on other sites
dodgemike 52 #10 Posted December 18, 2013 As a retired heavy equipment Operator this problem is not Unique to small tractors. Many Times in mud , crusher run etc. You have to pick up your blade Just a bit to get some weight Back on the front end to gain Control. You may leave a bit of Material behind, but a quick Clean up pass should do it. Sent from my SCH-S720C using Tapatalk 2 1 Share this post Link to post Share on other sites
Buzz 502 #11 Posted December 18, 2013 Tri Ribs! I didn't hear you. 1 Share this post Link to post Share on other sites
C-85 753 #12 Posted December 18, 2013 This is how I've attacked the steering problem, I've done about all that I can think of and it's better than its ever been, but it still slips some! I really like the roller chain idea and if I had seen that before I bought the snow hog tires I think I would have tried that first. 2 Share this post Link to post Share on other sites
tomtractor 71 #13 Posted December 18, 2013 (edited) Would 4.00-8 tri ribs fit on the C-125? If Anyone have a pair of tri-rib tires for sale mounted to rims, please pm me. Probably a long shot? Again, as always a lot of great ideas. Edited December 18, 2013 by tomtractor Share this post Link to post Share on other sites
Trouty56 567 #14 Posted December 18, 2013 Like dogemike said.....pick the blade up a bit for now......4.0/8's would probably fit on that 125 with tubes but might look like a little foot on a big leg if you know what I mean..... 1 Share this post Link to post Share on other sites
tomtractor 71 #15 Posted December 18, 2013 What size is recommended for the C-125? 1 Share this post Link to post Share on other sites
Coadster32 793 #16 Posted December 18, 2013 Just re-reading your question, looks like there's two issues. Loosing steering when loaded up with wood is a front weight issue, (assuming the wood weight is beyond the rear axle). Loosing steering when plowing is a side load, traction, and weight issue. I use tri-rib tires and weight on the front end when plowing,( weight under engine, and wheel weights). The roller chain idea is supposed to work very good. If you already have turfs, then I'd suggest trying the roller chain. You can take them off when not in winter, and not harm your lawn when you move around wood in your yard the rest of the year. Share this post Link to post Share on other sites
gomer gump 8 #17 Posted December 22, 2013 dodgemike is correct ,im also a retired hvy equip operator an disabled vet . I ran just about every piece of equip there is from 82-30 dozers to 72-31 loaders you name it , they will all skid when pushed to the limit . gold rush on cable tv they slide all over the place with d9l cats massive hvy equip . it,s all in the hands of the operator , to me wheel horses seem to work best mowing grass in the summer, my rototiller works really well for my garden , snow blowers work great and snow blades as long as you don,t try to overload them ,make a initial cut then do the final cut . in my years of running hvy equip I learned to slow down and make as many cuts as needed ,you,ll slide less an do a better smoother straighter job , patients prevailes . you can add all the wts front an rear and put on tires with special chains or whatever but I guarantee you it will still slide . what ever you can do to help it is fine . I personally wont put pounds of weights on the tractors I have weights just on the wheels and the wheel horse front wt kit ,that's it. too much wt an you,ll be fix n a axle or spindle real soon. my mighty mac chipper shredder works really good, last year built a 3 pt hitch for my 520h works good my loader tractor 520h works good but slides some in sand or dirt ,snow . when I haul wood with my 312 and trailor I load it up hvy and it does slide I just put it in lower gears an go slow usually ok . good new tires will also make a big difference 1 Share this post Link to post Share on other sites
