pezsox
Kohler K91 odd question...
pezsox
So I am putting my engine back together after painting and I have an odd question. I taped and cleaned the smooth metal areas where the carb and points are and I also taped off the area hi-lited in green. do that hole have anything that bolts there or is supposed to be located there. I have 20 pictures before I started and nothing from that angle. Just curious what goes there or if anything bolts there? I am sure everyone is getting a kick out of these ridiculous posts, but trust me I would have given up on this project long ago, had you all not been there.
at least I always include detailed pics!!! if only I took detailed pics to begin with haha
post-10744-0-35169600-1387221810_thumb.j
post-10744-0-84559100-1387221822_thumb.j
AMC RULES
On mine...the oil bath support bracket bolts up to the block there.
post-3498-0-77876600-1387223030_thumb.jp
squonk
I was going to say the A/C compressor bolts on there!
specialwheelhorse
Yep some have a little angled piece runs from there to choke or air cleaner area for support.
Jim
pezsox
well now you have all done it! haha This engine was never messed with and it has the oil bath hanging down, like I have seen some others on here. My bracket that was on there that supports the oil bath, bolts to one of the block bolts that secure the oil pan. Is there one way or the other that the oil works better?
AMC RULES
Here's a link for reference...
Which is your oil bath, the up or down draft version?   :scratchead:
Post a pict of the top and bottom of it here.
Edited by AMC RULES
wallfish
The updraft filter like you have, which is the correct version, should have the bracket which connects down at the oil pan hole. Craig's pic is the down draft version.
pezsox
so updraft means it is hanging down, and downdraft means it is up. Man it is like fiction/non fiction. lol
is there one that is preferable? I just want to make sure if my oil filter bracket does not go in that hole, I guess I just plug it with a bolt?
I apologize it will not let me rotate my pics, no clue why?
pezsox
also somewhat related... when you put the arm that is attached to the throttle cable on the governor should it be facing towards the carb or facing the other way towards the pulley?
AMC RULES
Is that the correct elbow/air inlet for an updraft air cleaner?
pezsox
now you have me worried. haha. here is every angle I can think of.
If everything does look correct, does there need to be a gasket/grommet where the wing nut rod comes up thru the bottom hole? or where it goes thru the top?
post-10744-0-12310000-1387298548_thumb.j
post-10744-0-24874700-1387298564_thumb.j
post-10744-0-26786100-1387298577_thumb.j
post-10744-0-16927400-1387298586_thumb.j
post-10744-0-51088500-1387298594_thumb.j
post-10744-0-84084700-1387298603_thumb.j
rj35hunter
I looked at all my RJ's and Suburbans and that hole is not used......
Clay
buckrancher
YES
The bell is longer on the updraft manifold so it misses the carb bowl
Brian
Edited by buckrancher
AMC RULES
Thank you Brian.
