C100 0 #1 Posted December 15, 2013 After pushing some heavy slush around I developed a clutch throw problem. (the belt was slipping and the clutch peddle was moving forward much more than it should) Fortunately, I finished the driveway and found that the Pin Spirol, P/N 933190 had broken in half so the linkage had moved on the shaft. I have driven the pin out and hopefully will be able to get one at a local Toro dealer. If I cannot, could someone suggest a substitute?? I think I will change the clutch belt at the same time.(7473) I was reading that these are prone to stretching. Is there a better brand or a higher quality substitute?? Thank you for any help. Share this post Link to post Share on other sites
sorekiwi 761 #2 Posted December 15, 2013 You should be able to pick up one of those roll-pins from a good hardware store. The IPL lists it as 3/16 x 1 1/4". A lot of guys swear by the genuine Toro belts. I have also used Gates belts and think they work well. I have Dayco's on a few of my tractors and don't think they are as long lasting as the Gates or Toro, but they are easy for me to get locally. Share this post Link to post Share on other sites
C100 0 #3 Posted December 20, 2013 I used a nut and bolt for now. That roll pin is a pin inside a pin. I am going to put a parts list together and order the exact replacement, hoping it will be the pin inside the pin. Thank you for the response. Share this post Link to post Share on other sites
Tankman 3,526 #4 Posted December 20, 2013 I too have used a lot of Gates belts, available locally, and not expensive. Share this post Link to post Share on other sites
