CHARGER9AUTO
Ben's '72 Commando 800
CHARGER9AUTO
I worked on my '72 Commando 800 today tinkerd around with it to fix the drive belt noise when you depress the Break to shift Gears. now it doesn't anymore what ever I've did the problem is solved. :banghead: :horseplay: :horseplay: Ben
Teddy da Bear
Good job! :banghead:
Glad you have had success today.
I have to do some troubleshooting of a similar nature on my A-800 Ranger.
Even though the lever for deck engagement is in the "disengaged" position the blades continue to rotate! :USA: That could be a bad thing...
CHARGER9AUTO
Even though the lever for deck engagement is in the "disengaged" position the blades continue to rotate! :omg: That could be a bad thing...
Mike, :USA: I need to work on my '73 8 HP 4-Speed next It's a Good runner tractor does not smoke or burn oil I had to clean the Carb on my 1045 because sometimes the Gas fills up in the float bowl. :thumbs: Ben
