CHARGER9AUTO 3 #1 Posted September 1, 2008 I worked on my '72 Commando 800 today tinkerd around with it to fix the drive belt noise when you depress the Break to shift Gears. now it doesn't anymore what ever I've did the problem is solved. :horseplay: :horseplay: Ben Share this post Link to post Share on other sites
Teddy da Bear 11 #2 Posted September 1, 2008 Good job! Glad you have had success today. I have to do some troubleshooting of a similar nature on my A-800 Ranger. Even though the lever for deck engagement is in the "disengaged" position the blades continue to rotate! That could be a bad thing... Share this post Link to post Share on other sites
CHARGER9AUTO 3 #3 Posted September 2, 2008 Good job! Glad you have had success today. I have to do some troubleshooting of a similar nature on my A-800 Ranger. Even though the lever for deck engagement is in the "disengaged" position the blades continue to rotate! That could be a bad thing... Mike, I need to work on my '73 8 HP 4-Speed next It's a Good runner tractor does not smoke or burn oil I had to clean the Carb on my 1045 because sometimes the Gas fills up in the float bowl. Ben Share this post Link to post Share on other sites
