greatlakespirate
belt type and size for 1965 wheel horse 875 wheel-a-matic
greatlakespirate
I can't seem to get a parts tech to understant what I need. I tell them it's a wheel horse 875, and they ask me for the model number under the seat. guess what, no model number under the seat. I need the size and type of drive belt. no mower or blower. thanks
Brrly1
The belt # you are looking for is #8005 which is a Wheel Horse belt. I am not sure on the model # but I am sure someone will step in with that info. Only reason I know this is because I have had a couple of them. If you look on ebay, you should be able to find one with no problem. If not pm me I have an extra
gwest_ca
Had Wheel Horse used decals under the seat back in 1965 your 875 model number is what would have been printed on it. Here is the operator manual and illustrated parts list.
The belt listed is number 6146 which has been replaced by number 8005. Dimensions listed are 1/2" x 72".
Gates replacement is 6872 and the same belt from Napa 4L720W. Best to get an original Toro belt if you can.
Garry
MalMac
Parts tech can't understand you because he/she has no clue about the older tractors. There is another perfect example of a Dealership not knowing squat. Boy Toro did good things for Wheel Horse but when they decided to drop the Wheel Horse line they also dropped service and caring. Go in now and they give you the deer in the headlights look. Wheel Horse what's that? My apology to the few remaining good Toro dealers still out there. Just very few of you left.
greatlakespirate
Thanks for all the great information. I finally realized why the belt was so loose when I traded out thr motors yesterday. some previous owner switched the drive pullys. so I spent the afternoon, close to two hours on each motor, pulling off and swapping the drive pullies. harbor freight pulley pullers, worthless, BIG hammer, and even bigger pry bar, priceless. todays job accomplished, tomorrow, attempt to replace the throttle cable. anyone out there no what the correct carb settings should be? oh yeah, almost forgot, I was able to plow with it tonight, but it moved alot slower than before, wonder whats up with that? again,thanks for the help.
Fordiesel69
The model plate is under the dash if seated on the tractor.  I have this tractor and had to get that info as well to get the transmission slider plate.
