shallowwatersailor 3,216 #1 Posted December 6, 2013 (edited) After not using my walk-behind snowblower the past two winters, I decided that this year it just has to snow! Sunday I went through prepping it, including starting it for the first time in two years. Wow, do those Tecumseh L-Heads make noise! One of the things I always check are the shear pins. I pull them to make sure the auger hasn't rusted to the shaft, and then coat them with anti-seize. One was difficult to get out (left side) and now I know why. It hadn't broken but it was sure weakened. The new replacement is on the right. Check yours if you have a chance. Edited December 6, 2013 by shallowwatersailor 1 Share this post Link to post Share on other sites
squonk 44,897 #2 Posted December 6, 2013 I had a big honkin blower on a little 210-H with no shear pins. Launched a chunk of 2x4 through it! Share this post Link to post Share on other sites
rmaynard 16,700 #3 Posted December 6, 2013 I got tired of the shear pins breaking on my 24" walk-behind from heavy, wet snow, so I replaced them with grade 8 bolts and nuts. No problems since. Share this post Link to post Share on other sites
oldredrider 2,553 #4 Posted December 6, 2013 GREAT!!! Now that you fixed your snowblower, it will never snow! I'm gonna put my mower deck back on! Share this post Link to post Share on other sites
AMC RULES 37,250 #5 Posted December 6, 2013 http://www.youtube.com/watch?v=BTZInS6ZG9Y Share this post Link to post Share on other sites
KATO 115 #6 Posted December 6, 2013 I use 5/16 stainless bolts for shear pins on mine.they don't shear at the drop of a hat and they do shear when you suck up some nasty stuff...haven't damaged anything YET Share this post Link to post Share on other sites
AMC RULES 37,250 #7 Posted December 6, 2013 You definitely don't want them to not shear. Share this post Link to post Share on other sites
eb in oregon 28 #8 Posted December 6, 2013 You definitely don't want them to not shear. Abso-freaking-lutely. Sometimes people forget that those pins are marginal on purpose. Humm, what's more expensive? Six or so shear bolts or the auger, drive shaft and other parts of the snow blower? I don't begrudge a few bucks and a few minutes replacing parts like that. I've seen the results of people "beefing up" things because they thought the original was "too weak." That costs a heck of a lot more in the end. 1 Share this post Link to post Share on other sites
shallowwatersailor 3,216 #9 Posted December 6, 2013 I think that the last time that I used my snowblower, I picked up a newspaper. It didn't seem to make a difference in performance so I let it go. Stainless bolts are a bit lighter in tensile strength than a standard bolt and won't rust so they are a nice alternative. Brass bolts would be more expensive - but weaker yet. I paid less than a buck a piece for eight replacements with nuts so at the rate I use them, I should be good for 16 years. The main thing is that nothing gets frozen due to rust which is why I pull them; the same thing with wheels and axle shafts. Snowblowers are definitely used in a wet environment. Share this post Link to post Share on other sites
