jeremi3210 743 #1 Posted December 4, 2013 Hello i lost one of my front wheel bearings plowing snow the snap ring came off and the bearing is gone anyway does anybody know where i can get a replacement? There is a napa just up the road. Thanks Share this post Link to post Share on other sites
rmaynard 16,745 #2 Posted December 4, 2013 (edited) Very common bearing. 1-3/8" OD, 3/4" ID flanged. Toro part number 110513. NAPA should be able to cross it. If not, they are used on John Deere and others. Edited December 4, 2013 by rmaynard Share this post Link to post Share on other sites
jeremi3210 743 #3 Posted December 4, 2013 Thanks rmaynard. I found the napa # 7-04292 and they have one. Another question, can you drill a hole in the spindle for a cotter pin? I dont want this to happen again. Share this post Link to post Share on other sites
rmaynard 16,745 #4 Posted December 4, 2013 There should be no reason why you can't drill a hole for a cotter pin 1 Share this post Link to post Share on other sites
W/H JUNKY 43 #5 Posted December 5, 2013 My local Ace hardware has the 1-3/8" OD, 3/4" ID flanged bearings. they are in the area when you pull out the little bolt totes. Share this post Link to post Share on other sites
leeave96 495 #6 Posted December 5, 2013 There should be no reason why you can't drill a hole for a cotter pin +1 totally agree!!! Share this post Link to post Share on other sites
Don1977 605 #7 Posted December 5, 2013 In my experience you need to find a good used front wheel if the bearing will not stay tight. I had that problem and the bearings would wear out in no time. Damaged my left front spindle. I still used that wheel on the back of a wagon, but it was a big problem on the front of my C-120. If it's a worker tractor the bearings need to fit tight. 1 Share this post Link to post Share on other sites
