Mike333 5 #1 Posted December 2, 2013 (edited) So winter is here and I went out to the garage to put the plow on the tractor for the first time, and of course it don't fit!!!! It mounts to the rear axel with two cam lock sorta antler thingy's, measures out to about 65 and 34 inches in overall length. I got it to mount to the axel but the control arm won't clear the footrest, and it looks like my brake and the drive pully won't clear the plow frame, also when i manually angled the plow there is not enough clearance for the front tires and it hangs up, any advice would be greatly appreciated!!! Happy Holiday's to everyone here at Red Square!!!! 1984 Wheel Horse Work Horse 42" inch Snow Plow(sorry no model #, looked all over for it) Edited December 2, 2013 by Mike333 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,011 #2 Posted December 2, 2013 Here is the manual for the 06-42BC02 blade sold at the time. IPL Notice on the cover there are 2 sets of holes for the rear crossbar. With this feature the blade will fit both short and long frame tractors. Your's is a long frame. Share this post Link to post Share on other sites
oldredrider 2,553 #3 Posted December 2, 2013 Sounds like your rear hitch may be mounted wrong. Share this post Link to post Share on other sites
Mike333 5 #4 Posted December 2, 2013 Here is the manual for the 06-42BC02 blade sold at the time. IPL Notice on the cover there are 2 sets of holes for the rear crossbar. With this feature the blade will fit both short and long frame tractors. Your's is a long frame. On my plow there is only the rear crossbar, no extra set of holes, and the crossbar is welded in place. Share this post Link to post Share on other sites
Mike333 5 #5 Posted December 2, 2013 (edited) I just read on the Toro parts finder site that there were several plows for this tractor, it says current model available is 06-42ST04, 06-48BC03 / 79364 ( 79364 requires Adapter kit 1051501) I'm am wondering if maybe i need an adapter kit? Can anyone tell me the differance in the three plows? or maybe shine some light on this adapter kit? Thanks guy's!!!! Edited December 2, 2013 by Mike333 Share this post Link to post Share on other sites
octfst 378 #6 Posted December 2, 2013 sounds like you have a short frame plow. they are about a foot shorter and the angle arm doesn't have to clear the running boards. Share this post Link to post Share on other sites
Mike333 5 #7 Posted December 2, 2013 Ok so i guess my next question is, can i make a short frame work by doing some fab work or should i just try to find a different plow for it? I work at a machine shop and have access to saws,welders,torches ext..... Share this post Link to post Share on other sites
octfst 378 #8 Posted December 2, 2013 Ok so i guess my next question is, can i make a short frame work by doing some fab work or should i just try to find a different plow for it? I work at a machine shop and have access to saws,welders,torches ext..... I would look at some other post. they have pictures of the bend in the angle arm to clear the running boards and a ext they make for some newer tractors. you would need to add about a foot in length and fab a arm with a bend. also will need to change lift point. chain might work. Share this post Link to post Share on other sites
