TravelinJavelin
ok i had to take a pic of my plow frame to confirm
TravelinJavelin
I think i'm pretty sure this a plow frame that fits the 520h with extension kit if it is i'd be willing to trade for a decent long frame system with the hardware to mount other than the rear hitch bracketpost-11959-0-41394400-1385922351.jpgpost-11959-0-71509600-1385922368.jpg
Callen
This will work on your tractor, it's just moved forward for tire clearance on the forward swept axle on the 520. Everything should line up.
69mach
Keep that extension.
Edited by 69mach
TravelinJavelin
but I will probably never own a 520, nice machine but I like the older machines better, just me
leeave96
Don't ever say never - LOL!
Keep the frame.
You might never own a 520H, but some day you might want to swap the front axle out of one into one of your tractors and you'd need this frame.
TravelinJavelin
well i'll keep the frame just not sure about extension now can that be used on anything else other than the 520h?
69mach
If I was closer I would trade with you. I've had 3 of those. The last one my friend & fabed up. It will work on any just needed for clearance with the forward swept axle.
69mach
Actually your angle arm is going to be different also. Might not work for you. I can see it in the pic.
TravelinJavelin
yeah I got to change that too
ericj
your pivot head is on backwards the rounded part goes towards the frame and the swivel lock pin goes into the holes on that part. hope fully you already knew this but just in case you didn't i thought i would let you know
 yea i would keep that extension kit you just never know when you might want to use it and it don't take up a lot of room to store good luck
eric j
TravelinJavelin
no I didn't know that i'm really glad you guys are telling me different things, your saving some aggravation for sure!
