bigboy63 1 #1 Posted November 29, 2013 Will a c series snow blower fit a 312-8 or a 416-h series tractor ? the snow blower has no tag on it . thanks Share this post Link to post Share on other sites
nylyon-(Admin) 7,882 #2 Posted November 29, 2013 Yes, if it's fitting on a C series it will fit on a 300 / 400 series. Share this post Link to post Share on other sites
Wyattrrp 59 #3 Posted November 29, 2013 I swapped a single stage blower from my C-125 to my 312-8 several times. Originally the low chute type with steel wheels and lever to change lower cutting bar height, Then the high chute with skids to set the depth of cut.to pavement. Others will chime in but as long as it fits into the front mount slot where the pulleys for the mower deck go, it will fit the 312-8. Same belt and many many years of blowers or plows are interchangeable. C series was early 80's like mine. 312 carried on the same frame and hookup design for many year. That is what makes the Red machine so great! You will need to be sure to get the lift rod that goes from the lift arm tot he bottome of blower and the lift flag that connects the lift arm to the lever on the left side of the tractor for lifting implements. Then you are good to go . Happy (brrrp!) day after turkeyday too! Wyatt. Share this post Link to post Share on other sites
bigboy63 1 #4 Posted November 30, 2013 Thanks guys picked it up 200 bucks . single stage short chute but will do for now with the steel wheels . Share this post Link to post Share on other sites
