slufoot733 70 #1 Posted November 24, 2013 The little skids on my snow thrower (single stange on a 1978 D-200) are about worn out. I was thinking of replacing the skids with a small wheel, adjustable for height. I'm looking at some small wheels, hard rubber tireon about a 4" steel wheel. Has anyone done this on a snow thrower/blower? If so, how well did it work for you? And did the wheel ware out quickly or did it last a while? Thanks for any imput....................................and HAPPY THANKSGIVING everyone! 1 Share this post Link to post Share on other sites
wallfish 18,428 #2 Posted November 24, 2013 I attached wheels to one but only to move it around when not on the tractor. I would think rubber wheels will wear fairly quick since they will be used as skids and constantly dragging sideways whenever you steer. How about using metal wheels like these? They sell them larger and smaller than the 3" one linked. They used steel wheels for skids on the older model blowers. http://www.tractorsupply.com/en/store/titan-casterstrade%3B-3-in-sintered-iron-plate-caster--rigid?cm_vc=-10005 Share this post Link to post Share on other sites
squonk 44,103 #3 Posted November 24, 2013 I put some adjustable wheel on my blower. They work good 8 Share this post Link to post Share on other sites
RMCIII 838 #4 Posted November 24, 2013 Mike, I was just getting ready to send him your way. Share this post Link to post Share on other sites
RMCIII 838 #5 Posted November 24, 2013 Someone else, in here, actually has one that came with steel wheels vs. skids. I've seen the photo, but I can't remember who it was. There was a lever on the side that adjusted the steel wheel height... Looked like it was well built. I was trying to find the photo, no luck yet. Share this post Link to post Share on other sites
RMCIII 838 #6 Posted November 24, 2013 Found one from ebay. Not a very good photo, but gives you an idea of the basic principal. Share this post Link to post Share on other sites
GlenPettit 1,717 #7 Posted November 25, 2013 (edited) Here's another view (wheels are in the 'up' position, scrape): Edited November 25, 2013 by GlenPettit Share this post Link to post Share on other sites
bitten 134 #8 Posted November 25, 2013 A snow thrower for a D is a heavy piece of equipment. Might just want to weld pieces of steel to your worn out shoes. Share this post Link to post Share on other sites
slufoot733 70 #9 Posted November 25, 2013 Sensational info everyone. Thank you. The skids are still usable but not for long. I like to plan ahead so I will study this a little more and come up with a solution. I like the idea of some kind of small wheels. The pneumatic tires are a nice plus but they're bigger than I was thinking about. Since 90% of my snow clearing work is done in a straight line I'm not worried about wearing them out when turning. However, the heavy steel wheel is a good idea. Share this post Link to post Share on other sites
Wishin4a416 2,192 #10 Posted November 25, 2013 I like your Mod Mike.When my skids wear out thats what I'll do. Share this post Link to post Share on other sites
timo4352 147 #11 Posted November 25, 2013 If you get to them before they completely wear out you can weld new metal onto them. That's what the previous owner did on mine. Two layers - so it's like 1/2 inch thick. Should last a while. Share this post Link to post Share on other sites
RMCIII 838 #12 Posted November 26, 2013 slu- check out classified. A 37" just posted that has the steel wheel adjustment...... Share this post Link to post Share on other sites
edwroy 138 #13 Posted December 11, 2013 Thanks for all the posts - Squonk's pics are what I was looking for. I like the idea of the rubber tires. Keeps from scratching the cement driveways/walks with the skids. Thanks - I plan to make this addition to my 42" tall chute. Edwroy Share this post Link to post Share on other sites
rokon 64 #14 Posted December 29, 2013 These may be of interest to you. you would have to measure yours and scroll down the page to where they list dimensions. http://snowblowerskids.com/place-an-order.html Share this post Link to post Share on other sites
Fun Engineer 859 #15 Posted December 29, 2013 I recently added this 1/2 inch piece of HDPE to the bottom of my worn skids. I wanted something that would glide over my concrete drive and stone parking pad. They work much better. Hope they last at least a season. So far they've been used on about 50+ inches of snowfall. 4 Share this post Link to post Share on other sites
RMCIII 838 #16 Posted February 15, 2014 I recently added this 1/2 inch piece of HDPE to the bottom of my worn skids. I wanted something that would glide over my concrete drive and stone parking pad. They work much better. Hope they last at least a season. So far they've been used on about 50+ inches of snowfall. I took your advice after finding out that new skids would cost $37.50/each before tax. Went to Walmat- found a nice 1/2" thick cutting board...... Took it home, made several molds for each skid. It takes about 15 minutes to remove the worn out ones and have the new ones on..... Nice info Fun! Sure came in hand for me. I have went through 1 set of original skids and 2 sets of the HDPE skids........ Course I clear anywhere from 8 to 12 driveways each time it snows, so, it is getting a lot of use. 2 Share this post Link to post Share on other sites
boovuc 1,090 #17 Posted February 15, 2014 I put High Density Polyethylene, (HDPE), on the bottom of my skids. If you google HDPE sheets you'll find some venders on-line for them. I use a thin sheet, about a 1/4 of an inch thick on my skids and run them a winter then evaluate if there is enough left for another year. I usually get two years from mine. They do not mark up a driveway as much as a metal skids do. I also use a thick piece, (about half to three-quarter inch), on the cutter of my snow plow. It also cuts down on marking up the driveway. It doesn't rip into the ice as well but it does a pretty good job. Share this post Link to post Share on other sites
Fun Engineer 859 #18 Posted February 15, 2014 (edited) I took your advice after finding out that new skids would cost $37.50/each before tax. Went to Walmat- found a nice 1/2" thick cutting board...... Took it home, made several molds for each skid. It takes about 15 minutes to remove the worn out ones and have the new ones on..... Nice info Fun! Sure came in hand for me. I have went through 1 set of original skids and 2 sets of the HDPE skids........ Course I clear anywhere from 8 to 12 driveways each time it snows, so, it is getting a lot of use. I forgot to mention that the cutting boards they sell in the home goods sections of most discount stores i.e. Walmart, Meijer (Michigan) have the cutting boards which are inexpensive, work great and give you plenty of material for many years to come. How did you mount yours to the skids? Post Script: We are currently at 143.9 inches of snow. 32.6 inches more than our annual average of 149 inches. Looking to break the record of 185.6" from 2006-2007. Disclaimer: These measurements are from the NOAA weather station located about 10 miles east of me. We always get more lake affect snow here than at the weather station. Edited February 15, 2014 by Fun Engineer Share this post Link to post Share on other sites
RMCIII 838 #19 Posted February 15, 2014 Fun - took off each original skid.... Found center of the skid, then drilled a hole 1-1/2" north and south of center. Then I laid the cutting board template under each skid, centered them then drilled a small pilot hole through the cutting board material..,, Then, took a wood bit, honed it out so the head of the bolt would be flush with the material.. Then I took a 5/16" bit and drilled out the remaining material.,,, 1 Share this post Link to post Share on other sites
Fun Engineer 859 #20 Posted February 22, 2014 Yep, same process here. I love the plastic. 1 Share this post Link to post Share on other sites
Joefrommi65 18 #21 Posted March 4, 2014 I was in tractor supply yesterday and they sell them there not sure if the bolt patern is the samethey are even red...lol If you need send me the distance between your holes and if you still need them let me know I will check them for you. Share this post Link to post Share on other sites
