traktorkidd7/30/93 1 #1 Posted August 31, 2008 Where can I find an oil pan gasket for a C-165 ? :banghead: Share this post Link to post Share on other sites
kpinnc 15,656 #2 Posted August 31, 2008 Get the model numbers of the engine, and spec numbers. They'll be on a tag on the flywheel cover. Then you can look the part number for the gasket up here, and NAPA auto parts can order one for you. You can also buy gasket material at any parts store, and make one. Good luck! Kevin Share this post Link to post Share on other sites
WH854 45 #3 Posted August 31, 2008 If its a K341 Kohler the Part # of the top of my head is 235057-S Try your Kohler Dealer. Cost about 3.75 + tax Chas From Butler Pa :banghead: Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted August 31, 2008 P/N 235353-S is the correct oil pan gasket for the earless block / small pan 341 in the C-165. 235057-S is for the big pan on the eared blocks. Share this post Link to post Share on other sites
