wheelhorse66 10 #1 Posted November 24, 2013 when i replace the rings on my kohler k181 should i replace anything else?the motor runs like a champ it just smokes at low rpms Share this post Link to post Share on other sites
buckrancher 2,695 #2 Posted November 24, 2013 You may want to do a quick valve lap and clearance check since the motor is torn down that far Brian Share this post Link to post Share on other sites
wheelhorse66 10 #3 Posted November 24, 2013 do i have to hone the cylinder wall to put rings in it Share this post Link to post Share on other sites
rmaynard 16,700 #4 Posted November 24, 2013 Without seeing it, I would say yes. Share this post Link to post Share on other sites
WH nut 553 #5 Posted November 24, 2013 (edited) I was told by an old timer that you should also replace the rod because it become brittle and the extra pressure from the new rings could cause it to break. Take it for what its worth, I didn't one time and ended up having to replace the rod after about 10 hours because it broke. Never did that again. Edited November 24, 2013 by WH nut Share this post Link to post Share on other sites
buckrancher 2,695 #6 Posted November 24, 2013 do i have to hone the cylinder wall to put rings in it yes or the new rings will not seat you should always hone a cylinder anytime you remove the piston and rings even if you are reinstalling the old ones brian Share this post Link to post Share on other sites
oldblue1993 98 #7 Posted November 24, 2013 I was told by an old timer that you should also replace the rod because it become brittle and the extra pressure from the new rings could cause it to break. Take it for what its worth, I didn't one time and ended up having to replace the rod after about 10 hours because it broke. Never did that again. Same thing happened to me, engine lasted only a few hours before i was in it again. "lesson learned,change rod" Share this post Link to post Share on other sites
