JamesC-120 204 #26 Posted August 1, 2014 They did not have 3 of the bearings at motion industries. So I got 2 of them at napa and just ordered the last one on amazon. But everything else is looking great. 1 Share this post Link to post Share on other sites
JamesC-120 204 #27 Posted August 1, 2014 I have a H60 tecumseh that I am going to put in the tractor but it has a dual shaft. My plan is to take my other Tecumseh H50 and swap half the block and the cam shaft. But I don't know if the cams are the same? The block is the same. Share this post Link to post Share on other sites
stevasaurus 23,816 #28 Posted August 1, 2014 Maybe...if this link works...this manual will help... http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0CCwQFjAC&url=http%3A%2F%2Fwww.asos1.com%2Ftecumseh4hp%2FTecumseh.pdf&ei=0_bbU4WmHJKzyATAsIGQBw&usg=AFQjCNHD3fZY0JTAGThMmHaiit6ZNAOz8A&sig2=k-vO3xd1Q3Y2vDWedI_IAg&bvm=bv.72197243,d.aWw Share this post Link to post Share on other sites
JamesC-120 204 #29 Posted August 1, 2014 (edited) They are the same so went to do the swap and the rod is destroyed and the piston and cylinder is scored. Where can you buy new piston and rod oversize? Edited August 1, 2014 by JamesC-120 Share this post Link to post Share on other sites
stevasaurus 23,816 #30 Posted August 1, 2014 James, at this point I would start a thread in the "Engine Section" about this. There are a couple guys on here that are into the Tecumsehs, but they will probably not see what you are trying to do here in transmissions. They may even have parts for you. Give it a shot. Share this post Link to post Share on other sites
