mark89 0 #1 Posted November 22, 2013 will a hydro lift setup on a charger automatic work on my hydro c120 Share this post Link to post Share on other sites
Trouty56 568 #2 Posted November 22, 2013 Good question....if you use the hydraulic valve off the Charger you will need a couple custom hoses made.....the 2 to the cylinder will be fine but the 2 to the pump will need to be customized.....bigger fittings on the pump side.... The different parts for the lift needed on the pump are not as easy as the older systems.....looks like you will need a ball bearing, change the relief valve spring to the other side and add an implement spring and possibly the cone from the Charger.....manual says use shims as needed????.....never really got into a later model pumps but somebody here has..... Probably a C-120/160 manual in the Manuals section....that's what I have here and am looking at..... Share this post Link to post Share on other sites
mark89 0 #3 Posted November 25, 2013 cool thanks i bailed on buying the tractor its more of a hunt for the outher parts then its worth gonna keep my eyes open for the parts to do it or a whole tractor thanks for the help Share this post Link to post Share on other sites
