HorseFixer 2,014 #1 Posted November 18, 2013 What weight and type of fluids do you use in the transmission and rear end of a senior? Thanks ~Duke Share this post Link to post Share on other sites
Fordiesel69 271 #2 Posted November 20, 2013 (edited) Preperation H What do you mean by senior, what model tractor? You have quite the colletion to guess. Edited November 20, 2013 by Fordiesel69 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,603 #3 Posted November 20, 2013 I used 80/90 in mine. If you saw what came out of it pretty much ANYTHING would have been better-lol. I also changed the gearbox and steering box oils as well. Share this post Link to post Share on other sites
shorts 182 #4 Posted November 20, 2013 I would imagine that old fashion 80/90W gear lube was factory fill, the multi-weight and synthetic products didn't exist back then, also would be concerned about seal compatability with the modern lubrication chemical composition. 1 Share this post Link to post Share on other sites
HorseFixer 2,014 #5 Posted November 29, 2013 Thanks Guy's I plan on replacing all Gaskets and Seals & Bearings where needed. Yes and I will switch over to Synthetics With Compatible Types. Share this post Link to post Share on other sites
