StWeiler
518H Bar Lift broke
StWeiler
Trying to get the last mow in for the season, all of a sudden the deck is hanging half out the side of the tractor.  Crawl under there and find that the bar lift broke.  The side opposite the bushing side.  I found all parts, but fear a weld will not suffice?  Has anyone had similar issue?  Did you just order/buy a new bar lift?
Aside from the parts tree diagram...are there any better pictures out there that I can reference when putting it back together?  I need to get it back up to get the snow plow on.
Thanks
leeave96
I can't speak to your lift bar - other than to say you probably can find a used one if you post to the classifieds a lot cheaper than buying a new one.
Good luck,
Bill
LFDRET
I have had good luck welding that same lift bar.
