W/H JUNKY 43 #1 Posted November 13, 2013 Hey All Do you guys use high temp paint for the engines when restoring them. Or will the normal raddle can paint work? Share this post Link to post Share on other sites
rmaynard 17,447 #2 Posted November 13, 2013 I paint my engines with the same paint as the rest of the tractor. The only part of the engine that gets hot enough to effect the paint is the area around the exhaust, and that will eventually turn dark even with high-temp engine paint. 2 Share this post Link to post Share on other sites
i967mustang 21 #3 Posted November 13, 2013 I used base coat/ clear coat on my C150 and painted the engine the same way. As mentioned above the only place that the paint burned off was right where the exhaust comes out. This even took awhile to burn off, I have had it painted for four years now. Share this post Link to post Share on other sites
W/H JUNKY 43 #4 Posted November 13, 2013 Great thanks guys Share this post Link to post Share on other sites
