rustyoldjunk 127 #1 Posted November 13, 2013 It doesn't look quite as nice as the pictures but it is a nice tractor over all. Its missing the mid Tach and has the wrong pulley on the engine but then thats another story too. It had a K301 big block engine from the factory and when it was "redone" they put a K181 off of a "pump" on it. The small block sets too low to be right with the belt guard so it does not stop the belt so it can be shifted. It just grinds. When i asked him about it ( after i already had it ) he said it always shifted fine. All i can say is i don't know how it ever did with this engine. I think instead of changing belt guards i may just try raising the engine. Any here are a few pics, I was messing around with different exhaust setup's in some of the pictures. 3 Share this post Link to post Share on other sites
Sparky-(Admin) 24,109 #2 Posted November 13, 2013 Yep, lift the motor some and check the pulley size. It looks like it might be to big and maybe the tractor goes a bit faster than stock . That seat looks real nice!! Mike.......... Share this post Link to post Share on other sites
AMC RULES 37,251 #3 Posted November 13, 2013 Nice haul... I'm thinkin' that tallest stack setup looks the best. Share this post Link to post Share on other sites
rustyoldjunk 127 #4 Posted November 13, 2013 Thanks Mike the seat i realy nice with one smallbad spot. Wounder if there is a way to fix it ? Now i want some factory arm rests. Nice haul... I'm thinkin' that tallest stack setup looks the best. Graig,you don't think it looks like overkill ? Share this post Link to post Share on other sites
AMC RULES 37,251 #5 Posted November 13, 2013 Not at all. Question is... does it sing? Share this post Link to post Share on other sites
rustyoldjunk 127 #6 Posted November 13, 2013 It seems to run great and sounds nice thru the biggest muffler. Share this post Link to post Share on other sites
speedyleedy 205 #7 Posted November 13, 2013 Nice looking tractor & sweet looking muffler ! Share this post Link to post Share on other sites
rustyoldjunk 127 #8 Posted November 13, 2013 Thanks Tim. Share this post Link to post Share on other sites
KC9KAS 4,745 #9 Posted November 13, 2013 Nice looking GT. Share this post Link to post Share on other sites
Kelly 1,035 #10 Posted November 13, 2013 With the 8hp they used a spacer plate about 1" tall I should have one if your looking or pics, and yes the drive pulley is to big Share this post Link to post Share on other sites
TravelinJavelin 620 #11 Posted November 13, 2013 nice looking machine there! Share this post Link to post Share on other sites
546cowboy 302 #12 Posted November 13, 2013 That is a really nice looking tractor and deserves a K-301 put back in it. Share this post Link to post Share on other sites
Wheel-N-It 2,976 #13 Posted November 13, 2013 Nice haul... I'm thinkin' that tallest stack setup looks the best. I'm with Craig on the stack. Share this post Link to post Share on other sites
Wheel Horse Kid 105 #14 Posted November 13, 2013 That sure does look clean! Nice haul! I like the tall stack the best. Have you considered going back to the stock 12 hp? Share this post Link to post Share on other sites
rustyoldjunk 127 #15 Posted November 14, 2013 (edited) That is a really nice looking tractor and deserves a K-301 put back in it. That sure does look clean! Nice haul! I like the tall stack the best. Have you considered going back to the stock 12 hp? I would love to have a 12HP back on it or even a 14HP-16HP but for now it will probably be cheaper to fix the situation with the 8HP that is on it. I'm really surprised at how many of you like the tall stack the best. I really though it was too much. Anyone else have thoughts on which exhaust looks best ? Edited November 14, 2013 by rustyoldjunk 1 Share this post Link to post Share on other sites
posifour11 723 #16 Posted November 14, 2013 Personally, I like the last one. Share this post Link to post Share on other sites
roscoemi 245 #17 Posted November 14, 2013 I'd like the tall muffler with a little smaller pipe on top, but about the same height. Share this post Link to post Share on other sites
sorekiwi 761 #18 Posted November 14, 2013 Like Kelly said the B80's used a Riser plate to lift the small engine up. Nice tractor! Share this post Link to post Share on other sites
