Butch 194 #1 Posted November 11, 2013 When you put these chains on you really get a beating riding the tractor. I'm even afraid that the tractor rocks or twists so much it could crack the frame at the transmission. I was wondering if you ran about 5 pounds of air if it would soften the ride up. How do you guys run your rubber chains? Share this post Link to post Share on other sites
CasualObserver 3,414 #2 Posted November 11, 2013 PM MaineDad. If I remember right, he used to sell these or at least promote them. Share this post Link to post Share on other sites
GlenPettit 1,718 #3 Posted November 12, 2013 I have never used the "Rubber Chains", but would think the tires need to inflated higher (20psi) to make sure the chains stay on tight, a softer tire might have them loose and then come off. The more cross-links, the less bounce; a "2-link Chain" has cross links every 2-3 inches and gives a fairly smooth ride, whereas a "4-link Chain" has the links every 5-6" and has a noticeable bounce. A softer tire with 5psi would give a smoother softer ride, but then also reduces traction in the Winter. A harder tire with lots of weight is best, and the chains greatly increase traction, especially when starting to get into trouble. Share this post Link to post Share on other sites
shallowwatersailor 3,220 #4 Posted November 12, 2013 I bought a set for the 518xi two years ago and they are now mounted on my 520xi. They do ride a bit rough on dry asphalt but when it snows (a rarity here in MD the last two years,) the ride does get smoother. I have been happy with them, and they are effective in getting traction on ice. I have dug ruts in the dirt and they don't slip on the wheel. What is especially nice about them is that they do not mark the pavement as chains do. 1 Share this post Link to post Share on other sites
Butch 194 #5 Posted November 12, 2013 I've only used the rubber chains once for about 4" of snow. Those chains rattled my teeth and like I said before I was concerned about the twisting of the frame cracking at the transmission. Share this post Link to post Share on other sites
