Guest jjs #1 Posted November 11, 2013 good afternoon, I just bought a c161 and I am trying to restore it. Front wheels have a lot of play, wheels move in and out on the spindle axle and the spindle is loose as well, is this normal or do I have a problem, thanks Share this post Link to post Share on other sites
flyovrcntry 115 #2 Posted November 11, 2013 I would say,look at manual or parts list.You could have the wrong wheels,or something as simple as missing spacer.If the bearing fits the axle,I would say put a spacer in to make up the difference. Share this post Link to post Share on other sites
rmaynard 16,291 #3 Posted November 12, 2013 Spindles do wear, as well as the holes in the axle where the spindles go through. For the in-out movement, you probably need a couple of shims. As long as the movement within the axle is not too excessive, I wouldn't be too concerned. Spindles are still available new if needed, and the axles can be bored out and bushings installed. Share this post Link to post Share on other sites
1978wh 0 #4 Posted November 12, 2013 If the bearings are not loose on the spindle or wheel hub , you are probably fust missing the spacers. Share this post Link to post Share on other sites
Wheel-N-It 2,976 #5 Posted November 12, 2013 Welcome to Red Square. I would jump in with some advice, but you have heard from Maynard. He is the expert. Shoot us some pics of your 161 so we can see what kind of shape it is in overall. Share this post Link to post Share on other sites
Guest jjs #6 Posted November 13, 2013 Here it is, I dont have to tell you the parts removed. I plan on replacing the bearings and see if the play goes away, are these wheel horse bearings or can I pick them up somewhere else, that is at a reasonable price. thanks 2 Share this post Link to post Share on other sites
bowtiebutler956 650 #7 Posted November 13, 2013 (edited) Here it is, I dont have to tell you the parts removed. I plan on replacing the bearings and see if the play goes away, are these wheel horse bearings or can I pick them up somewhere else, that is at a reasonable price. thanks That looks like a very solid foundation for a Great Restoration! Gotta love any powered by the big K341 Thumper!! You can buy the 3/4x 1 3/8 wheel bearings for these on for about $10 for a set of 4. I'll PM you a link. Matt Edited November 13, 2013 by bowtiebutler956 Share this post Link to post Share on other sites
W/H JUNKY 43 #8 Posted November 13, 2013 Hi jjs This is just my personal preference but I like to use brass thrust washers between the inside of the rim and the spindle and one on the outside between the rim and the cotter pin. I get them from Ace Hardware or Gilroys Hardware. Gilroys calls them brass bearing and Ace calls them Brass thrust washers. They come in different thicknesses so you can take up alittle or alot of space if needed. Also these will wear before the harder metal will. Hope this helps. Chris. Share this post Link to post Share on other sites
Wheel-N-It 2,976 #9 Posted November 13, 2013 You can pick up the wheel bearings at NAPA. I don't know the part number of the top iof my head. Just knock out the old bearings and take them to NAPA. The guys there will cross reference some for you. Share this post Link to post Share on other sites
JC 1965 1,532 #10 Posted November 13, 2013 Good looking tractor. I really like the C-160 model. If you find that your spindles need to be replaced, you can pm kelly ( he is a vender on here ) I purchased a pair of spindles from him with very little wear, and at a very good price. He is a great guy to deal with. Hope this helps !! Share this post Link to post Share on other sites
Guest jjs #11 Posted November 16, 2013 thank you for the help, bearings replaced, much better. Now on to the hood, lower corner rusted through, as in holes. I am a pretty good welder but the hood and too many curved recesses, i guess we are at the bond or fiberglass stage, but hate to go there. Any thoughts? Share this post Link to post Share on other sites
jjs 0 #12 Posted April 23, 2014 jjs I need help Wheelhorse fans! I have a c161 with a kohler k341as, battery ignition, that I am restoring and presently trying to put back together. The rectifier has 3 tabs, but there are 4 wires coming out of the engine (stator). Yes I know, take better notes next time, any ideas on how to figure out what goes where? Share this post Link to post Share on other sites
jjs 0 #13 Posted May 28, 2014 ok, nearly done. I am looking for a 42" deck, the one that came with it is mostly holes, any suggestions? thanks Share this post Link to post Share on other sites
Sparky-(Admin) 23,138 #14 Posted May 28, 2014 ok, nearly done. I am looking for a 42" deck, the one that came with it is mostly holes, any suggestions? thanks Not sure where Niskayuna is (is it a real place ) but scroll thru the classifieds right here on Redsquare. Maybe post a wanted ad as well. Mike........... Share this post Link to post Share on other sites
mrc 937 #15 Posted May 28, 2014 hello sir, end play for wheels is .000-..015 per the wh manual. i use different thickness shims to get the right amount of end play. i like the above mentioned brass thrust washer idea from chris. best regards mike in mass. Share this post Link to post Share on other sites
