MalMac 1,332 #1 Posted November 5, 2013 My C-145 auto has got a strange thing going on with the engine. When I start the tractor with the hydro disengaged the engine will carry on running ruff. It has a completely rebuilt carb on it. New jets, float, etc. everything except a new throttle bushing. Still seems tight to me. Now when I engage the transmission and put a little load on the motor it calms right down, smooths out and runs perfect. Without a pull on the motor it just starts acting up. Could not ask for a better running Kohler when it's got a load on it. It even gets hard to start without a load on it. Crazy and strange to me. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,512 #2 Posted November 5, 2013 Bad engine grounds? Garry Share this post Link to post Share on other sites
MalMac 1,332 #3 Posted November 5, 2013 You know what you might have something there. It's got that shaker plate on it. Did not even think of that. Share this post Link to post Share on other sites
squonk 43,939 #4 Posted November 5, 2013 That engine moves around more than you think. When I was working on my C-145, engaging the PTO caused the flywheel screen to barely touch the shroud due to crankshaft end play I guess. But you can see the motor defect when engaging . If the carb is causing your problem, sounds like it's tad rich. Wonder if the float level is a bit high Share this post Link to post Share on other sites
WH nut 553 #5 Posted November 5, 2013 When you say runs rough? are you saying surging, missing ? Share this post Link to post Share on other sites
MalMac 1,332 #6 Posted November 5, 2013 Rough as in missing, stutter, hack cough,etc. no surging. Share this post Link to post Share on other sites
WH nut 553 #7 Posted November 5, 2013 Sounds like Carb adjustment Share this post Link to post Share on other sites
rmaynard 16,363 #8 Posted November 5, 2013 When you put the engine under load, the governor kicks in, opening the throttle. This seems to be your biggest clue. Check for air leaks. Throttle shaft, gaskets, loose bolts, etc. Pull the high speed needle again and check to be sure that a small bit of debris has not clogged any of the tiny holes in the tube. Share this post Link to post Share on other sites
